Errro After Updating Webtop to 1.5.4
Module: Webtop
I am getting the following error after updating my instance of Webtop
Error: mounting storage for container acd59e445213a8b5986c40c6afdecfe0afed479488de3e2a64f4f15de3a5ff45: creating overlay mount to /home/webtop1/.local/share/containers/storage/overlay/a16a0d472acd2d304f8fe44a0946f0ea92a9078f6814b05b3133dbd815e8ca21/merged, mount_data="lowerdir=/home/webtop1/.local/share/containers/storage/overlay/l/POPZ6W7ONBAS2BZBZCGGXI7EIN:/home/webtop1/.local/share/containers/storage/overlay/l/E7MNY6S3F7UGRB2WEWYQZ5PCZW:/home/webtop1/.local/share/containers/storage/overlay/l/FEI4I4I2E2VT3D6WR524X6CK67:/home/webtop1/.local/share/containers/storage/overlay/l/KUE2CXEJHC5SAAIKVBD3PLYBKF:/home/webtop1/.local/share/containers/storage/overlay/l/ZBVFFGYK4VJVDUSKTM2LB57IKC:/home/webtop1/.local/share/containers/storage/overlay/l/WTZOWAVMUNRUU4FEL6O4GX3DWL:/home/webtop1/.local/share/containers/storage/overlay/l/AMD2FFFNMOAE5EOKLM4KYCZEZI:/home/webtop1/.local/share/containers/storage/overlay/l/JQAYBE2ATBUFSHKLEMXSL2QHL5:/home/webtop1/.local/share/containers/storage/overlay/l/MBVRAN6NGNFURS2XK3SRNPXRWP:/home/webtop1/.local/share/containers/storage/overlay/l/SWL3HMQO7IX72BRXN3MK2SQKAX:/home/webtop1/.local/share/containers/storage/overlay/l/KAB2NVEJZSNH5ZSU2UO53WQGXI,upperdir=/home/webtop1/.local/share/containers/storage/overlay/a16a0d472acd2d304f8fe44a0946f0ea92a9078f6814b05b3133dbd815e8ca21/diff,workdir=/home/webtop1/.local/share/containers/storage/overlay/a16a0d472acd2d304f8fe44a0946f0ea92a9078f6814b05b3133dbd815e8ca21/work,userxattr,volatile,context=\"system_u:object_r:container_file_t:s0:c103,c591\"": input/output error
  File "/home/webtop1/.config/actions/get-defaults/20readconfig", line 34, in <module>
    accepted_timezone_list = subprocess.check_output(['podman', 'run', '--log-driver=none', '--replace', '--name', 'list-timezones', '--rm', os.environ["WEBTOP_WEBAPP_IMAGE"], 'java', '-classpath', '/usr/share/webtop/', 'ListTimeZones'], text=True).splitlines()
  File "/usr/lib64/python3.11/subprocess.py", line 466, in check_output
    return run(*popenargs, stdout=PIPE, timeout=timeout, check=True,
  File "/usr/lib64/python3.11/subprocess.py", line 571, in run
    raise CalledProcessError(retcode, process.args,
subprocess.CalledProcessError: Command '['podman', 'run', '--log-driver=none', '--replace', '--name', 'list-timezones', '--rm', 'ghcr.io/nethserver/webtop-webapp:1.5.4', 'java', '-classpath', '/usr/share/webtop/', 'ListTimeZones']' returned non-zero exit status 126.
My Settings seem to have been reset as well
Logs
41b35aedfd1245c2681038d71f80c0b50590599cc6c95dd7f18d/work,userxattr,volatile,context=\"system_u:object_r:container_file_t:s0:c504,c1023\"": input/output error
2025-12-19T22:26:56+03:00 [1:webtop1:runagent] Traceback (most recent call last):
2025-12-19T22:26:56+03:00 [1:webtop1:runagent]   File "/home/webtop1/.config/bin/discover-ldap", line 74, in <module>
2025-12-19T22:26:56+03:00 [1:webtop1:runagent]     domain_setup(os.getenv("MAIL_DOMAIN"), user_domain)
2025-12-19T22:26:56+03:00 [1:webtop1:runagent]                            ^^^^^^^^^^^^^^^^^^^^^^^^
2025-12-19T22:26:56+03:00 [1:webtop1:runagent]     user_domain_password = subprocess.check_output(
2025-12-19T22:26:56+03:00 [1:webtop1:runagent]   File "/home/webtop1/.config/bin/discover-ldap", line 30, in domain_setup
2025-12-19T22:26:56+03:00 [1:webtop1:runagent]   File "/usr/lib64/python3.11/subprocess.py", line 466, in check_output
2025-12-19T22:26:56+03:00 [1:webtop1:runagent]            ^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^
2025-12-19T22:26:56+03:00 [1:webtop1:runagent]     return run(*popenargs, stdout=PIPE, timeout=timeout, check=True,
2025-12-19T22:26:56+03:00 [1:webtop1:runagent]   File "/usr/lib64/python3.11/subprocess.py", line 571, in run
2025-12-19T22:26:56+03:00 [1:webtop1:runagent]     raise CalledProcessError(retcode, process.args,
2025-12-19T22:26:56+03:00 [1:webtop1:runagent] subprocess.CalledProcessError: Command '['podman', 'run', '--replace', '--name', 'webtop-pass-encode', '--rm', '-i', 'ghcr.io/nethserver/webtop-webapp:1.5.4', 'java', '-classpath', '/usr/share/webtop/', 'WebtopPassEncode']' returned non-zero exit status 126.
2025-12-19T22:26:56+03:00 [1:webtop1:podman] ffe20a8350f78f5d98bddc7e809f271ee6043b646bd5ce42e5b95cb5e25f6e22
2025-12-19T22:26:56+03:00 [1:webtop1:systemd] webapp.service: Control process exited, code=exited, status=1/FAILURE
f26de4f4398150c34e5aa7dc8db50dfa4a3960c5cf01934699956/work,userxattr,volatile,context=\"system_u:object_r:container_file_t:s0:c133,c856\"": input/output error
2025-12-19T22:27:02+03:00 [1:webtop1:runagent] Traceback (most recent call last):
2025-12-19T22:27:02+03:00 [1:webtop1:runagent]   File "/home/webtop1/.config/bin/discover-ldap", line 74, in <module>
2025-12-19T22:27:02+03:00 [1:webtop1:runagent]   File "/home/webtop1/.config/bin/discover-ldap", line 30, in domain_setup
2025-12-19T22:27:02+03:00 [1:webtop1:runagent]     domain_setup(os.getenv("MAIL_DOMAIN"), user_domain)
2025-12-19T22:27:02+03:00 [1:webtop1:runagent]                            ^^^^^^^^^^^^^^^^^^^^^^^^
2025-12-19T22:27:02+03:00 [1:webtop1:runagent]     user_domain_password = subprocess.check_output(
2025-12-19T22:27:02+03:00 [1:webtop1:runagent]   File "/usr/lib64/python3.11/subprocess.py", line 466, in check_output
2025-12-19T22:27:02+03:00 [1:webtop1:runagent]     return run(*popenargs, stdout=PIPE, timeout=timeout, check=True,
2025-12-19T22:27:02+03:00 [1:webtop1:runagent]   File "/usr/lib64/python3.11/subprocess.py", line 571, in run
2025-12-19T22:27:02+03:00 [1:webtop1:runagent]            ^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^
2025-12-19T22:27:02+03:00 [1:webtop1:runagent]     raise CalledProcessError(retcode, process.args,
2025-12-19T22:27:02+03:00 [1:webtop1:runagent] subprocess.CalledProcessError: Command '['podman', 'run', '--replace', '--name', 'webtop-pass-encode', '--rm', '-i', 'ghcr.io/nethserver/webtop-webapp:1.5.4', 'java', '-classpath', '/usr/share/webtop/', 'WebtopPassEncode']' returned non-zero exit status 126.
2025-12-19T22:27:02+03:00 [1:webtop1:systemd] webapp.service: Control process exited, code=exited, status=1/FAILURE
2025-12-19T22:27:02+03:00 [1:webtop1:systemd] webapp.service: Failed with result 'exit-code'.
2025-12-19T22:27:02+03:00 [1:webtop1:systemd] Failed to start WebTop webapp.
2025-12-19T22:27:02+03:00 [1:webtop1:systemd] webapp.service: Consumed 1.657s CPU time.
2025-12-19T22:27:03+03:00 [1:webtop1:systemd] webapp.service: Scheduled restart job, restart counter is at 4.
2025-12-19T22:27:03+03:00 [1:webtop1:systemd] Stopped WebTop webapp.
2025-12-19T22:27:03+03:00 [1:webtop1:systemd] webapp.service: Consumed 1.657s CPU time.
2025-12-19T22:27:03+03:00 [1:webtop1:systemd] Starting WebTop webapp...
2025-12-19T22:27:03+03:00 [1:webtop1:runagent] webtop.properties: use builtin fragment webtop.properties.d/10builtin
2025-12-19T22:27:03+03:00 [1:webtop1:runagent] webtop.properties: use builtin fragment webtop.properties.d/20pecbridge
2025-12-19T22:27:03+03:00 [1:webtop1:runagent] webtop.properties: use builtin fragment webtop.properties.d/30ui
2025-12-19T22:27:03+03:00 [1:webtop1:runagent] webtop.properties: use builtin fragment webtop.properties.d/31theme
2025-12-19T22:27:03+03:00 [1:webtop1:runagent] renamed 'webtop.properties.tmp' -> 'webtop.properties'
2025-12-19T22:27:04+03:00 [1:webtop1:runagent] Error: mounting storage for container 2c5b92663acda0d5f28a0624c2b0dbde89c1fe0a33e6ab17197f7cecab7c6073: creating overlay mount to /home/webtop1/.local/share/containers/storage/overlay/450f3e30c4ceebb73e3ca709f142816442b76587958242f733ca32593fa7f6e8/merged, mount_data="lowerdir=/home/webtop1/.local/share/containers/storage/overlay/l/POPZ6W7ONBAS2BZBZCGGXI7EIN:/home/webtop1/.local/share/containers/storage/overlay/l/E7MNY6S3F7UGRB2WEWYQZ5PCZW:/home/webtop1/.local/share/containers/storage/overlay/l/FEI4I4I2E2VT3D6WR524X6CK67:/home/webtop1/.local/share/containers/storage/overlay/l/KUE2CXEJHC5SAAIKVBD3PLYBKF:/home/webtop1/.local/share/containers/storage/overlay/l/ZBVFFGYK4VJVDUSKTM2LB57IKC:/home/webtop1/.local/share/containers/storage/overlay/l/WTZOWAVMUNRUU4FEL6O4GX3DWL:/home/webtop1/.local/share/containers/storage/overlay/l/AMD2FFFNMOAE5EOKLM4KYCZEZI:/home/webtop1/.local/share/containers/storage/overlay/l/JQAYBE2ATBUFSHKLEMXSL2QHL5:/home/webtop1/.local/share/containers/storage/overlay/l/MBVRAN6NGNFURS2XK3SRNPXRWP:/home/webtop1/.local/share/containers/storage/overlay/l/SWL3HMQO7IX72BRXN3MK2SQKAX:/home/webtop1/.local/share/containers/storage/overlay/l/KAB2NVEJZSNH5ZSU2UO53WQGXI,upperdir=/home/webtop1/.local/share/containers/storage/overlay/450f3e30c4ceebb73e3ca709f142816442b76587958242f733ca32593fa7f6e8/diff,workdir=/home/webtop1/.local/share/containers/storage/overlay/450f3e30c4ceebb73e3ca709f142816442b76587958242f733ca32593fa7f6e8/work,userxattr,volatile,context=\"system_u:object_r:container_file_t:s0:c437,c829\"": input/output error
2025-12-19T22:27:04+03:00 [1:webtop1:runagent] Traceback (most recent call last):
2025-12-19T22:27:04+03:00 [1:webtop1:runagent]   File "/home/webtop1/.config/bin/discover-ldap", line 74, in <module>
2025-12-19T22:27:04+03:00 [1:webtop1:runagent]     user_domain_password = subprocess.check_output(
2025-12-19T22:27:04+03:00 [1:webtop1:runagent]   File "/home/webtop1/.config/bin/discover-ldap", line 30, in domain_setup
2025-12-19T22:27:04+03:00 [1:webtop1:runagent]     domain_setup(os.getenv("MAIL_DOMAIN"), user_domain)
2025-12-19T22:27:04+03:00 [1:webtop1:runagent]                            ^^^^^^^^^^^^^^^^^^^^^^^^
2025-12-19T22:27:04+03:00 [1:webtop1:runagent]   File "/usr/lib64/python3.11/subprocess.py", line 466, in check_output
2025-12-19T22:27:04+03:00 [1:webtop1:runagent]     return run(*popenargs, stdout=PIPE, timeout=timeout, check=True,
2025-12-19T22:27:04+03:00 [1:webtop1:runagent]   File "/usr/lib64/python3.11/subprocess.py", line 571, in run
2025-12-19T22:27:04+03:00 [1:webtop1:runagent]            ^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^
2025-12-19T22:27:04+03:00 [1:webtop1:runagent] subprocess.CalledProcessError: Command '['podman', 'run', '--replace', '--name', 'webtop-pass-encode', '--rm', '-i', 'ghcr.io/nethserver/webtop-webapp:1.5.4', 'java', '-classpath', '/usr/share/webtop/', 'WebtopPassEncode']' returned non-zero exit status 126.
2025-12-19T22:27:04+03:00 [1:webtop1:runagent]     raise CalledProcessError(retcode, process.args,
2025-12-19T22:27:04+03:00 [1:webtop1:systemd] webapp.service: Control process exited, code=exited, status=1/FAILURE
2025-12-19T22:27:04+03:00 [1:webtop1:systemd] webapp.service: Failed with result 'exit-code'.
2025-12-19T22:27:04+03:00 [1:webtop1:systemd] Failed to start WebTop webapp.
2025-12-19T22:27:04+03:00 [1:webtop1:systemd] webapp.service: Consumed 1.596s CPU time.
2025-12-19T22:27:05+03:00 [1:webtop1:systemd] webapp.service: Scheduled restart job, restart counter is at 5.
2025-12-19T22:27:05+03:00 [1:webtop1:systemd] Stopped WebTop webapp.
2025-12-19T22:27:05+03:00 [1:webtop1:systemd] webapp.service: Consumed 1.596s CPU time.
2025-12-19T22:27:05+03:00 [1:webtop1:systemd] Starting WebTop webapp...
2025-12-19T22:27:05+03:00 [1:webtop1:runagent] webtop.properties: use builtin fragment webtop.properties.d/10builtin
2025-12-19T22:27:05+03:00 [1:webtop1:runagent] webtop.properties: use builtin fragment webtop.properties.d/20pecbridge
2025-12-19T22:27:05+03:00 [1:webtop1:runagent] webtop.properties: use builtin fragment webtop.properties.d/30ui
2025-12-19T22:27:05+03:00 [1:webtop1:runagent] webtop.properties: use builtin fragment webtop.properties.d/31theme
2025-12-19T22:27:05+03:00 [1:webtop1:runagent] renamed 'webtop.properties.tmp' -> 'webtop.properties'
2025-12-19T22:27:06+03:00 [1:webtop1:runagent] Error: mounting storage for container 71927bb78c73358b6c20e601e026f824dc567412484a3fc0c02a02d11a84bdcb: creating overlay mount to /home/webtop1/.local/share/containers/storage/overlay/f303475c43a0765fdc5a97b47b553443887e5bf26e12dd8cec3f542bdbd4d75e/merged,
It seems you have no mail instance installed but it’s needed by Webtop.
I have, and had a working webtop on the same server. this only happened After Updating
Following checkbox in the mail domain is enabled?
yes it has been
Maybe a storage or selinux issue?
Is the disk full?
Disk is perfectly fine..
might running api cli update module form terminal resolve the issue, or would ti introduce other more issues..
Since its the Webmail client, What do i stand to lose whe i reinstall, if it cant be resolved…
xmpp had been enabled, and i know i had tons of configs on the webtop side alone…
Would attempting to restore backups help…
WebTop 1.5.4 was released on October 28th so I don’t think it’s an upgrade bug.
Input/Output error usually is about a hardware/filesystem issue so I’d check the disk for errors.
You could try it. Update-module shouldn’t introduce more issues and you could restore to a new app instance so the original app isn’t touched.
