Errors from AutoMySQLBackup
Hello,
I got last days such errors from MySQL Backup:
mysqldump: Couldn't execute 'show create table `wphh_uap_action_logs_view`': SHOW VIEW command denied to user 'backupuser'@'localhost' for table 'wphh_uap_action_logs_view' (1142)
The error is also generated when the command is triggered manually
/sbin/e-smith/runmysqlbackup-rh-mariadb103
The table wphh_uap_action_logs_view is related to my WordPress installation within a vhost and is empty.
It corresponds to the plugin Uncanny Automator.
That plugin works well.
What should I do? Is it a problem with AutoMySQLBackup or UA?
Within this Module, I can delete/reset tables.
Sincerely, Marko
IMVHO…neither
The error is pretty strightfoward.
'backupuser'@'localhost' cannot execute the command show create table wphh_uap_action_logs_view
(remove some of backticks to allow code formatting)
Maybe that user have not the rights to dump tables that seems… logs? IDK, I don’t use Wordpress. Maybe you can simply add that ACL on MySQL for that tables.
Yes probably a command to allow backupuser to show these tables
I have never allowed the show command. I think i never needed it. Does it is your only issue or others mysql database are with the same issue ?
Hi Stephane, that’s the only one system with this error,
Certainly clearly related to the WordPress module. Thanks for the tips.
I will try it.
Sincerely, Marko
I granted backupuser to the WP-DB
ariaDB [(none)]> SHOW GRANTS FOR 'backupuser'@'localhost';
| Grants for backupuser@localhost        |
| GRANT SELECT, LOCK TABLES, EVENT ON *.* TO `backupuser`@`localhost` IDENTIFIED BY PASSWORD '*AB078BC771F653B32E9A58DA' |
| GRANT ALL PRIVILEGES ON `dbhegeringwp01`.* TO `backupuser`@`localhost`        |
But the error still remains, a little bit different.
ERROR 1045 (28000): Access denied for user 'backupuser'@'localhost' (using password: YES)
best regards, Marko
I have to reopen the issue, because the error persists.
Daily I get mail with following information:
checking directory "/var/lib/nethserver/automysqlbackup-rh-mariadb103//daily" ... exists.
checking directory "/var/lib/nethserver/automysqlbackup-rh-mariadb103//weekly" ... exists.
checking directory "/var/lib/nethserver/automysqlbackup-rh-mariadb103//monthly" ... exists.
checking directory "/var/lib/nethserver/automysqlbackup-rh-mariadb103//latest" ... exists.
checking directory "/var/lib/nethserver/automysqlbackup-rh-mariadb103//tmp" ... exists.
checking directory "/var/lib/nethserver/automysqlbackup-rh-mariadb103//fullschema" ... exists.
checking directory "/var/lib/nethserver/automysqlbackup-rh-mariadb103//status" ... exists.
# Testing for installed programs
pigz ... found.
mysql ... found.
mysqldump ... found.
mail ... found.
# Parsing databases ... Note: Parsed config file /etc/automysqlbackup/rh-mariadb103.conf.
Error: The mysql server is empty, i.e. no databases found. Check if something is wrong. Exiting.
and
As I wrote before, I granted the backupuser with credentials.
What can I do?
Sincerly, Marko
Deja read? Did you not already had this kind of issue on ‘backupuser’@‘localhost’ ?
Yes, but the solution didn’t help.
I could not take care of it the whole time and have now taken up the problem again.
now I removed and reinstalled the application.
The error still remains when executing /sbin/e-smith/runmysqlbackup-rh-mariadb103
pigz ... found.
mysql ... found.
mail ... found.
and 2nd Mail
config show automysqlbackup:
automysqlbackup=configuration
    Backup_local_files=
    Backupdir=/var/lib/nethserver/automysqlbackup
    DbPassword=<not changed PW>
    Dbencrypt_password=01234567899876543210
    Encrypt=no
    Hour=3
    Mailcontent=log
    Mailto=<mymail>
    Minute=1
    Sizemail=8000
Any ideas are highly welcome.
Thank you all, Marko
