Upon applying updates, I got an error message instructing me to copy and paste the command to a terminal prompt, and paste the output. Here it is, it looks good to me. After rebooting system, it says there are 0 updates.
[root@roy ~]# echo ‘{“action”:“update”,“packages”:[]}’ | /usr/bin/setsid /usr/bin/sudo /usr/libexec/nethserver/api/system-packages/update | jq
“state”: “running”,
“steps”: -1,
“event”: “Initialization”
“state”: “running”,
“steps”: -1,
“event”: “Resolving RPM dependencies”
“state”: “running”,
“steps”: -1,
“event”: “Downloading Packages”
“state”: “running”,
“steps”: -1,
“event”: “Running Test Transaction”
“state”: “running”,
“steps”: -1,
“event”: “Running Transaction”
“status”: “success”,
“steps”: -1,
“event”: “Transaction end”
“state”: “success”
[root@roy ~]#
