Hi i have faced with issue in Password module while adding password to user:
Nethgui:
500 - Internal server error
1366796122+1322149476
Nethgui:
[root@nethserver /]# stat /tmp
File: `/tmp'
Size: 4096 Blocks: 8 IO Block: 4096 directory
Device: fd01h/64769d Inode: 260099 Links: 6
Access: (0770/drwxrwx---) Uid: ( 498/ srvmgr) Gid: ( 14/ uucp)
Access: 2016-01-12 23:31:58.986554560 +0200
Modify: 2016-01-12 23:41:01.558295971 +0200
Change: 2016-01-12 23:41:01.558295971 +0200
Assign permitions:
chown srvmgr:uucp /tmp
No. I’d say:
[filippo@nethservice ~]$ rpm -qf /tmp/
filesystem-2.4.30-3.el6.x86_64
[filippo@nethservice ~]$ rpm -V filesystem
[filippo@nethservice ~]$ stat /tmp/
File: `/tmp/'
Size: 552960 Blocks: 1088 IO Block: 4096 directory
Device: fd01h/64769d Inode: 51380225 Links: 19
Access: (1777/drwxrwxrwt) Uid: ( 0/ root) Gid: ( 0/ root)
$ ls -ld /tmp/
drwxrwxrwt. 19 root root 552960 Jan 12 23:28 /tmp/
Then, my commands would be:
chmod 1777 /tmp
chown root:root /tmp
I think you’re system is a bit messed up.
Please run
rpm -Va
to check integrity of all packages.
it is my test horse
