NethServer Version: 7.3.1611
Module: System
[ 55.591747] system-readhea[638]: failed to open pack files: Read-only file system
Unattended installation, 2 HD, 8 Gb Ram.
After installation, the server starts normally.
I do the updates and install the packages I need and reboot I get this console error.
The server is reachable at ip address but there are no active services.
Restart the server with the third “rescue” item and it all goes.
If I restart the server normally without making any choices at startup, the error resumes.
Formatted and reconfigured at least three times, do I get something wrong?
I have to install the packages and then do the updates or vice versa, can this be the problem?
When to elect the machine to domain controllers, before installing packages and upgrades or afterwards?
Is there a sequence to be respected?
Problem HW?
The server and HD are new.
