Error connecting to NS8: ns8-join: a matching external AD domain was not found in NS8
Hello,
I am getting the following error in the migration tool, and I gave up after 4 hours of debugging and hacking:
Error connecting to NS8: ns8-join: a matching external AD domain was not found in NS8.
Is there any way to to debug this, see what is matching and what don’t?
Thank you!
Does the NS7 use an external account provider?
In that case you need to create it on the NS8, see also NethServer 7 migration — NS8 documentation
Hello,
Sorry, last night I wrote a detailed post but at the end I did not send it as I thought I am bout to solve it… 1 hour later I restored the VMs, but the draft was gone by then.
External Windows Server AD
NS7:
Joined using LDAP - last night I tried to rejoin it as Active Directory (this was the idea when I discarded the previous draft of this post), but it failed at trying to connect to _ldap._tcp.ad.domain.tld which I could not hack successfully in any way, even tried with AdDns in command line in "action":"remote-ad" (possibly then I got other error, I don’t remember), or even altering the joining script.
LDAP server URI: ldap://server.ad.domain.tld
STARTTLS: No
Base DN: OU=abc,DC=ad,DC=domain,DC=tld
User DN: OU=abc,DC=ad,DC=domain,DC=tld
Group DN: OU=abc,DC=ad,DC=domain,DC=tld
Bind DN: CN=xyz,OU=Service Accounts,OU=abc,DC=ad,DC=domain,DC=tld
Bind Password: 123456
Note: when I tried to install NS8 DokuWiki and got stuck due to translated group names on windows Server, then I added new admins and reorganized the groups, and OU=abc was introduced back then, so I updated these settings. I have checked, the default groups disappeared and the new ones appeared.
NS8:
server.ad.domain.tld:389
Schema: ad
Bind password: 123456
TLS: Disabled
TLS verify: Disabled
For me the looks identical - I do not know if LDAP/AD method means a difference or not.
So I would like to debug it deeper to see the actual reason.
As I would need only mailing and roundcube to migrated, I also checked the migration script to get idea what should be done if I would copy everything manually, but I am afraid to proceed due to all the permissions and the whole containerization.
Thank you for your help!
SOVLED
Finally…
Removed server. from beginning the NS7 LDAP server URI, and rejoined NS8 with the same changes, and now it works…
Huh… :zipper_mouth_face:
