Error after Onlyoffice upgrade
NethServer Version: 7.9
Module: nextcloud 22.2.3
I have several servers with NC 22.2.3 and OnlyOffice document server 6.4.xxxx working correctly.
Yesterday, on one, the app OnlyOfiice got disabled.
I went to check as NC admin and saw that the 7.0.2 connector was disabled and marked as “application not verified” and that the 7.3.0 update was ready.
I checked the other servers that still work and I saw that the connector installed is version 7.2.0 …
I proceeded with the update of the connector on the server not working, the OnlyOffice was re-enabled but with the already known error “violates local access rules”, I ran the command in WiKi and when I went to click “SAVE”, NC it told me that 7.3.0 was not compatible with document server 6.4.xxx.
Next step, update the document server to version 7.0.0 … Everything looked ok, but …
Will you help me? Thank you
Schermata da 2022-01-21 12-28-09
(an error occurred while opening the file. Click on “OK” to return to the document list).
This error always appears, existing or newly created documents.
Thanks for reporting. I can confirm the issue with onlyoffice-documentserver 7.0.0-132. I need to check, I’m afraid a DB upgrade isn’t working correctly. This is the error I got after updating:
Incorrect DB_TYPE value! Possible value of DB_TYPE is 'postgres' or 'mysql'.
warning: %post(onlyoffice-documentserver-7.0.0-132.x86_64) scriptlet failed, exit status 1
It seems to be compatible to document server 6.4.2-6:
grafik
As a workaround you could downgrade:
yum downgrade https://github.com/ONLYOFFICE/DocumentServer/releases/download/v6.4.2/onlyoffice-documentserver.x86_64.rpm
Reapply config and restart services:
signal-event nethserver-onlyoffice-update
Great job.
Done, now all OK
Sorry, bat in your wiki:
Is this an error?
Grazie 1000
No, it’s meant to replace x.x.x.x with the actual version.
Some time ago the rpm name and location changed, I just wanted to point that out.
Yes, I corrected it.
:ok_hand:
Grazie
Recreating the database solves the issue regarding the update to documentserver 7.0, see wiki.
Not here…
Screenshot 2022-01-22 100707
Regards
Uwe
Did you try to completely remove documentserver, remove the database and install documentserver 7 again?
Did you find relevant log entries?
Please also share your installed onlyoffice RPMs.
rpm -qa *onlyoffice*
Here it’s working on 2 servers. I’m going to try to reproduce your issue later.
Hi mrmarkuz, after a long period with covid i am a little bit confused.
Here is th output of rpm -qa *onlyoffice*:
rpm -qa onlyoffice
nethserver-onlyoffice-0.0.2-1.ns7.noarch
I have updated to version 7.0.0 as you described in your instructions. After that I have renewed the database.
Edit:
And then I have this error in the log of my NC that keeps repeating:
Error onlyoffice Exception: Im Dokumentenservice ist ein Fehler aufgetreten: Conversion error
/usr/share/nextcloud/apps/onlyoffice/lib/documentservice.php - line 94:
OCA\Onlyoffice\DocumentService->ProcessConvServResponceError("-3")
/usr/share/nextcloud/apps/onlyoffice/lib/preview.php - line 269:
OCA\Onlyoffice\DocumentService->GetConvertedUri(“https://clo … 0”, “xlsx”, “jpeg”, “2511239571”)
/usr/share/nextcloud/lib/private/Preview/ProviderV1Adapter.php - line 53:
OCA\Onlyoffice\Preview->getThumbnail(“Arbeitszeit … 9”, 4096, 4096, false, OC\Files\View {})
/usr/share/nextcloud/lib/private/Preview/GeneratorHelper.php - line 62:
OC\Preview\ProviderV1Adapter->getThumbnail(OC\Files\Node\File {}, 4096, 4096)
/usr/share/nextcloud/lib/private/Preview/Generator.php - line 245:
OC\Preview\GeneratorHelper->getThumbnail(OC\Preview\ProviderV1Adapter {}, OC\Files\Node\File {}, 4096, 4096)
/usr/share/nextcloud/lib/private/Preview/Generator.php - line 140:
OC\Preview\Generator->getMaxPreview(OC\Files\Sim … {}, OC\Files\Node\File {}, “application … t”, “”)
/usr/share/nextcloud/lib/private/Preview/Generator.php - line 109:
OC\Preview\Generator->generatePreviews(OC\Files\Node\File {}, [ { width: 4 … }], “application … t”)
/usr/share/nextcloud/lib/private/PreviewManager.php - line 189:
OC\Preview\Generator->getPreview(OC\Files\Node\File {}, 44, 44, true, “fill”, “application … t”)
/usr/share/nextcloud/apps/files_versions/lib/Controller/PreviewController.php - line 99:
OC\PreviewManager->getPreview(OC\Files\Node\File {}, 44, 44, true, “fill”, “application … t”)
/usr/share/nextcloud/lib/private/AppFramework/Http/Dispatcher.php - line 217:
OCA\Files_Versions\Controller\PreviewController->getPreview(OC\Files\Node\File {}, 44, 44, “1641914319”)
/usr/share/nextcloud/lib/private/AppFramework/Http/Dispatcher.php - line 126:
OC\AppFramework\Http\Dispatcher->executeController(OCA\Files_Ve … {}, “getPreview”)
/usr/share/nextcloud/lib/private/AppFramework/App.php - line 156:
OC\AppFramework\Http\Dispatcher->dispatch(OCA\Files_Ve … {}, “getPreview”)
/usr/share/nextcloud/lib/private/Route/Router.php - line 302:
OC\AppFramework\App::main(“OCA\Files_ … r”, “getPreview”, OC\AppFramew … {}, { _route: "f … "})
/usr/share/nextcloud/lib/base.php - line 1006:
OC\Route\Router->match("/apps/files_versions/preview")
/usr/share/nextcloud/index.php - line 36:
OC::handleRequest()
Edit 2: Downgraded to V 6.4.2 and everything works well.
I could reproduce the issue. I thought it’s just about removing the DB but maybe removing and installing onlyoffice did the trick.
It should work with following steps but I recommend to stay with version 6.4 until 7.0 is more integrated (for instance metrics doesn’t start because it uses the same port as netdata).
I think I need to provide a module update.
yum -y remove onlyoffice-documentserver
su - postgres -c "psql -c 'drop database onlyoffice;'"
yum -y install https://github.com/ONLYOFFICE/DocumentServer/releases/download/v7.0.0/onlyoffice-documentserver.x86_64.rpm
yum -y install nethserver-onlyoffice
Good Morning mrmarkuz and thank you for helping me.
In general, the installation of version 7 works as you described above. But then the scan throws me this error message. Possibly the system seems to expect another file. I followed your recommendation and reinstalled version 6.4.2 completely. But the error message remains. See pictures…
I could reproduce, I guess the integrity check fails because the onlyoffice app changed a file in Nextcloud. It’s not a big problem and can be ignored.
The recommended way is just replacing the file Nextcloud complains about, see wiki or Nextcloud docs.
Get the right nextcloud-x.x.x.zip, should be 22.2.3:
wget https://download.nextcloud.com/server/releases/nextcloud-22.2.3.zip
Backup the file:
cp /usr/share/nextcloud/core/js/mimetypelist.js ~
Maybe you need to install unzip:
yum install unzip
Unzip the file to the Nextcloud path:
unzip -j nextcloud-22.2.3.zip nextcloud/core/js/mimetypelist.js -d /usr/share/nextcloud/core/js
Clean up:
rm nextcloud-22.2.3.zip
I found that reinstalling Nextcloud removes the warning too as it restores all files to the original ones but I had issues with onlyoffice afterwards so I DO NOT recommend it in this case…
Now it works like before. Thank you.
Hi mrmarkuz,
after a update to the latest version of NC the red message is back again. But everything works without problems.
I can’t reproduce the warning on my servers.
Could you please share the “list of invalid files” to check if it’s an issue?
Here i have a pic of the “list of invalid files”.
It can be ignored, it’s the same as here.
Ok, i will do so.
Thank you…
