Hello,
after activating tls by changing hostname from ldaps to ldap and save the changes
get this error:
Error
Configuration not edited.
The following command has failed:
system-accounts-provider/update
Unfortunately we couldn’t catch the exact error. If you want to help, please click on the button below to copy the failed command to the clipboard, paste it into the Terminal and submit command output to the developers.
echo'{"StartTls":"enabled","BindPassword":"xxxxxxxxxxxxxxx","BaseDN":"dc=ad,dc=xx,dc=xx","BindDN":"ldapservice@xxxx","LdapURI":"ldap://nsdc-th.xxx","UserDN":"dc=ad,dc=xx,dc=xx","GroupDN":"dc=ad,dc=xx,dc=xx","action":"bind-credentials"}' | /usr/bin/setsid /usr/bin/sudo /usr/libexec/nethserver/api/system-accounts-provider/update | jq
> "steps": 7,
> "pid": 22258,
> "args": "",
> "event": "nethserver-sssd-save"
> "step": 1,
> "pid": 22258,
> "action": "S01nethserver-sssd-cleanup",
> "event": "nethserver-sssd-save",
> "state": "running"
> "progress": "0.14",
> "time": "0.041756",
> "exit": 0,
> "state": "done",
> "step": 1,
> "pid": 22258,
> "step": 2,
> "pid": 22258,
> "action": "S05generic_template_expand",
> "state": "running"
> "progress": "0.29",
> "time": "0.396429",
> "exit": 0,
> "state": "done",
> "step": 2,
> "pid": 22258,
> "step": 3,
> "pid": 22258,
> "action": "S20nethserver-sssd-conf",
> "state": "running"
> "progress": "0.43",
> "time": "0.361344",
> "exit": 0,
> "state": "done",
> "step": 3,
> "pid": 22258,
> "step": 4,
> "pid": 22258,
> "action": "S30nethserver-sssd-initkeytabs",
> "state": "running"
> "progress": "0.57",
> "time": "2.963454",
> "exit": 0,
> "state": "done",
> "step": 4,
> "pid": 22258,
> "step": 5,
> "pid": 22258,
> "action": "S50nethserver-webtop5-conf-db",
> "state": "running"
> "progress": "0.71",
> "time": "0.549874",
> "exit": 0,
> "state": "done",
> "step": 5,
> "pid": 22258,
> "step": 6,
> "pid": 22258,
> "action": "S80nethserver-sssd-notifyclients",
> "state": "running"
> "progress": "0.86",
> "time": "17.467381",
> "exit": 256,
> "state": "done",
> "step": 6,
> "pid": 22258,
> "step": 7,
> "pid": 22258,
> "action": "S90adjust-services",
> "state": "running"
> "progress": "1.00",
> "time": "11.507961",
> "exit": 0,
> "state": "done",
> "step": 7,
> "pid": 22258,
> "pid": 22258,
> "status": "failed",
and how can check if ldaps work or not?
Best regards
