I’ve been playing with NethServer 2.0 beta (7.2.15.11) and here’s a suggestion for displaying IP addresses in the IP Reservation tab. Let’s say you have the following IP addresses: 192.168.1.9, 192.168.1.2, 192.168.1.200 and 192.168.1.10. If you sorted by IP Address, it would look like
192.168.1.10
192.168.1.2
192.168.1.200
192.168.1.9
Ideally, it would look like this:
192.168.1.2
192.168.1.9
192.168.1.10
192.168.1.200
I suspect that the easiest way to get it to look like the above is:
192.168.001.002
192.168.001.009
192.168.001.010
192.168.001.200
I currently assign devices to specific buckets manually so that it’ll be easier to find them and then it’s easier to sort it by IP address so I can see the gaps.
We use https://datatables.net/ component to display tables: it supports sorting on special formats. Please dig it to see if an IP sorting plugin is available and test it: we could merge it with our server-manager
