@dan would like to enable opcache for my rpm nethserver-php-scl by default, this is the QA
if you can have a go or comment on what I will break for you ?
this enable opcache for the scl remi-php73,72,71
The only possible downside I’d anticipate is increased resource (probably RAM) usage to hold the cache–I guess folks on resource-constrained systems might see some impact.
yep I released the rpm, we use the value of nextcloud, I suppose it is quite safe, thank for your inputs dan
