When we change a password of an user in Nethgui and Cockpit, the password of ejabberd does not work.
It is needed to add “ejabberdctl clear-cache”.
I have already said here: https://github.com/NethServer/dev/issues/5931.
No change after several days.
In more, no news about all my changes (without problem) for a perfect ejabberd in NethServer 7.7.
Thanks in advance.
stephdl
(Stéphane de Labrusse)
2
probably it only needs to make an action in nethserver-ejabberd with a 90 score to clear the cache with the event password-modify
stephdl
3
stephdl
4
but this won’t work if the authenticator is remote
stephdl
5
try this rpm @neustradamus
An official dev has said: ejabberd and LDAP password problem · Issue #3091 · processone/ejabberd · GitHub
Maybe there is a problem in documentation.
Previously I have done the command with clear-cache, it has been worked.
stephdl
7
No tested the pr, please test it and correct the path to command if necessary
stephdl
8
it seems that in the code it is related to clear_cache, but clear-cache does not trigger errors
[root@ns7loc14 ~]# /opt/ejabberd-*/bin/ejabberdctl clear_cache
[root@ns7loc14 ~]# /opt/ejabberd-*/bin/ejabberdctl clear-cache
[root@ns7loc14 ~]# man ejabberdctl
No manual entry for ejabberdctl
I tested the PR, no error so far in logs I let you the argumentation to make it accepted…my work is done here
No problem
But strange about the dev for the mistake, and the feature works with “-”, I had tested.
It is like 2 possibilities work.
@stephdl: Any news for this security change?
And about my request to rename:
- root/etc/e-smith/events/actions/nethserver-ejabberd-clearCache to root/etc/e-smith/events/actions/nethserver-ejabberd-clear-cache.
- createlinks: nethserver-ejabberd-clearCache -> nethserver-ejabberd-clear-cache
