After Upgrade of Ejabberd some days ago - I think according to following changes - [https://github.com/NethServer/dev/issues/6070]
the HTTP Upload is not working any more.
I found that template expansion of /etc/ejabberd/ejabberd.yml does not expand the @HOST@ in my case correctly.
The template file /etc/e-smith/templates/etc/ejabberd/ejabberd.yml/85Modules
has followowing entry at the end of the file
Changing file /etc/ejabberd/ejabberd.yml manually with the real FQN (instead or the @HOST@ ) in line to something like put_url: "https://myhost.mydomain.com:5443/upload" and restarting the ejabberd.service manually makes the HTTP Upload service working correctly.
Is this an issue in general or do I have some misconfiguration so that the @HOST@ is not expanded correctly?
Then I have the issue that my public URL is different then the internal hostname.
E.g. in WebTop or NextCloud Modules it is possible to define PublicURL or TrustedDomains to reflect the external access.
In my case the internal host/domain is used inside the ejabberd config for the ejabberd Upload URL - which is then obviously not working.
Side topic: I found in /etc/ejabberd/ejabberd.yml that the Definition of âhostâ (I guess this is the variable defined to be used by ejabberd as you explained) is showing only the domain - hostname is missing. Anyway (as discibred above) this would not solve the situation anyway in my case.
So my unqualified guess would be that for ejabberd module also some kind of PublicURL variable should be introduced to be able to have different external URL for accessing ejabberd from outside.
@stephdl I think itâs just a problem because the Nethserver domainname is a not resolvable local one like âlocal.lanâ and therefore the download links are not working.
@jrieder You may use this custom template if itâs no option to change the Nethserver domain:
I use an internal domainname on one of my servers too and itâs a pain.
I can only recommend to use a public domain name as Nethserver domain just to avoid similar problems.
Hello, sorry for the late reply as I was sick the entire week.
Today I could test the suggested approach by mrmarkuz:
However - not working as expected!
hosts: parameter then includes the external hostname: As all users are however bound to the internal domain name, no user can login any more. The ejabberd admin web page cannot be accessed any more. (In the ejabberd.yml config file all the admin users are configured still with the internal domain name - so also no admin user can login into the ejabberd webpage. ==> so actually not usable
I tested to use two virtual hosts in the âhosts:â section of ejaberd.yml. (Internal domain and external domain). Then the users can sign in again - assume with the internal domain. However then still no HTTP upload is possible as most probably each user (and the connected users are still bound to the internal domainname) would use each domain also for the HTTP uplink put_url (by using @HOST@ parameter in the put_url
With this setup however the @HOST@ parameter in the put_url is mandatory - so cannot override this parameter to the external domain name.
So current solution I see is to have an âexternalâ domain parameter replacing ONLY the HTTP upload put_url parameter and keeping in the hosts: only the internal domain.
Maybe I missed something and maybe there are better ideas?
Thanks and regards!
