Improvements suggestions Nextcloud.
In Nethserver 7, when ejabberd was installed, because it had cortun built into it, it was possible to make use of that coturn to be able to work for nextcloud as a turn server,
Now in NS8, i dont see how its possible to achieve this. equally, on the Nextcloud Image, i do not see that cortun, and any turn or sturn components within the services, meaning, either an external component is required or something else.
How is Nextcloud talk supposed to work in this regards.
High Performance Signalling.
couldn’t this docker image be added to nextcloud Module: strukturag/nextcloud-spreed-signaling: Standalone signaling server for Nextcloud Talk. (github.com)
considering things are now containerized, its much easier to add it into the Module all at once.
Moving forward, we could then add Configurations for Files High PErfomance from here:
nextcloud/notify_push: Update notifications for nextcloud clients (github.com)
There is a nice article on this as well here: Nextcloud 21: High Performance Backend for Files » DecaTec
since redis is already supported in the container, unless this config was already factored in, and implemented by default in our Nextcloud Module.
what do you think abotu Above.
i am thinking a NS8 module of this, would make it possible to conenct nextcloud into it, and make use of it as the signaling server…
I was watching the NExtcloud 30 keynote release today, and this borgin issue came to mind yet again.
@davidep this is targeted at you.
Could we and are we to have these additional features and improvements into Nextcloud? I have mentioned this topic across many topics, ever since Nethserver 7, and while NS7 had its limitations, we no longer have them in NS8.
So could we please have these improvement and upgrades into the core nextcloud server from the core development team Please?
HIGH PERFORMANCE BACKEND FOR TALK
HIGH PERFORMANCE BACKEND FOR FILES
@giacomo Thank you for taking your time and Adding High Performance Backend feat: add file high performance backend by gsanchietti · Pull Request #135 · NethServer/ns8-nextcloud
In release Release 1.4.0 · NethServer/ns8-nextcloud · GitHub
This was a highly requested Feature since Hub4 and i am glad its now been considered and added into NC
nextcloud-spreed-signaling/docker/docker-compose.yml at master · strukturag/nextcloud-spreed-signaling
services:
spreedbackend:
build:
context: ..
dockerfile: docker/server/Dockerfile
platforms:
- "linux/amd64"
volumes:
- ./server.conf:/config/server.conf:ro
network_mode: host
restart: unless-stopped
depends_on:
- nats
- janus
- coturn
nats:
image: nats:2.10
volumes:
- type: bind
source: ./gnatsd.conf
target: /config/gnatsd.conf
read_only: true
command: ["-c", "/config/gnatsd.conf"]
network_mode: host
janus:
build: janus
command: ["janus", "--full-trickle"]
network_mode: host
coturn:
image: coturn/coturn:4.6
network_mode: host
# Update command parameters as necessary.
# See https://github.com/coturn/coturn/blob/master/README.turnserver for
# available options.
command:
- "--realm"
- "nextcloud.domain.invalid"
- "--static-auth-secret"
- "static_secret_same_in_server_conf"
- "--no-stdout-log"
- "--log-file"
- "stdout"
- "--stale-nonce=600"
- "--use-auth-secret"
- "--lt-cred-mech"
- "--fingerprint"
- "--no-software-attribute"
- "--no-multicast-peers"
coturn
coturn/docker at master · coturn/coturn
