eJabberd - OMEMO
(Gerald) #1
Hello,
I use the eJabber service to stay in contact with the world :wink:
Messaging internally and externally works, but what does not work is the encryption with OMENO.
I have read something and found that this is only from a newer version of eJabber or if you add some additional modules.
Is there now a possibility to update to a new version? I can update the module manually - but he only throws up errors afterwards …
Alternatives possible?
Ejabberd 18.06 bug or issue
(Giacomo Sanchietti) #2
I know that @stephdl has ejabberd on his radar, but the work is quite difficult because it needs a full rewrite of configuration template.
Regarding OMENO, I don’t what it is. Could you provide some links?
(Gerald) #3
(Stéphane de Labrusse) #4
@giacomo @davidep where does the rpm ejabberd-16.01 come from ?
It comes from nethserver-base, but I cannot find the src.rpm nor source in github ?
(Davide Principi) #5
It comes from the ejabberd repos!
(Stéphane de Labrusse) #6
https://docs.ejabberd.im/admin/upgrade/#specific-version-upgrade-notes
:smiley:
some stuff to study
https://docs.ejabberd.im/admin/upgrade/from_17.03_to_17.06/
https://docs.ejabberd.im/admin/upgrade/from_17.06_to_17.09/
https://docs.ejabberd.im/admin/upgrade/from_17.09_to_17.11/
https://docs.ejabberd.im/admin/upgrade/from_17.11_to_18.01/
https://docs.ejabberd.im/admin/upgrade/from_18.01_to_18.03/
(Giacomo Sanchietti) #7
Just for reference, some work has already been done, you find come commits here: https://github.com/gsanchietti/nethserver-ejabberd/tree/yaml
