Can you add a function for 5223 port?
It is not needed by default.
But you can enable by default for old machine.
Admin must to quickly disable in interface.
Can you add a function for MUC?
Can you add a function for BOSH?
Can you add a function for WebSockets?
Can you add a function for API?
Can you add a function to choice the port of BOSH?
Can you add a function to choice the port of HTTP UPLOAD?
Can you add a function for CAPTCHA?
Can you add a function to enable vhosts? (like for email)
Can you add a function to choice the ejabberd webamin lang (“en” by default)?
We are not going to add more options on ejabberd, especially mqtt since nobody uses it.
If you need such configuration, please use a template-custom.
I do not see any really relevant change on ejabberd 20.30. @stephdl if you think it worth the effort, please open the issue and link the existing PR to it.
IMHO we can stay with ejabberd 20 for a while if there are no severe security issues.
i am really having a hard time understanding the use cases for ejabberd.
also, i installe dit to see how it looks and functions, but i cannot access its user interface because/
i do not know the default username and password.
can someone enlighten me please.
What I would like to demonstrate is there is no regressions, so in short, firs we install the stable, then we upgrade and check you can create a salon, talk with mates, do upload of files etc etc
After changing version and another systemctl daemon-reload ejabberd was working properly.
Create room works
Chat and upload/download works
Found some warnings in /var/log/ejabberd:
2020-04-04 02:41:08.147 [warning] <0.106.0>@ejabberd_config_transformer:warn_removed_option:539 Option 'log_rotate_date' is deprecated and has no effect anymore. Please remove it from the configuration.
2020-04-04 02:41:08.147 [warning] <0.106.0>@ejabberd_config_transformer:warn_removed_option:539 Option 'log_rate_limit' is deprecated and has no effect anymore. Please remove it from the configuration.
2020-04-04 02:41:08.315 [warning] <0.106.0>@gen_mod:warn_soft_dep_fail:582 Module mod_mam is recommended for module mod_muc but is not found in the config
I tested with Xabber on Android and Pidgin on Windows. More tests will follow (encryption etc)
Example of configuration, please look all, there are a lot of changes between NethServer ejabberd configuration, example you use 5223 by default and it is not here:
need to check, new obsolete settings, did I never say that I do not like this software
2020-04-04 11:34:21.255 [warning] <0.106.0>@ejabberd_config_transformer:warn_removed_option:539 Option 'log_rotate_date' is deprecated and has no effect anymore. Please remove it from the configuration.
2020-04-04 11:34:21.255 [warning] <0.106.0>@ejabberd_config_transformer:warn_removed_option:539 Option 'log_rate_limit' is deprecated and has no effect anymore. Please remove it from the configuration.
