Today I’ve been working on my backup jobs to adjust the settings. But at the end of the Edit where I click on Edit to save my changes the backup window is not closing. I can only press Back or Cancel. If I cancel my jobs is not saved.
Has there been a change to Backup recently that would have caused this issue?
Has anyone else found the same problem?
Edit: I’ve now tried to create a new scheduled backup and I was unsuccessful. I’ve went through the backup wizard successfully. On the last screen I press schedule and the box does not close. The only buttons that work are back and cancel. Schedule is not working.
Hello @federico.ballarini,
I’ve confirmed this morning that all updates are installed:
Kernel Release - 3.10.0-1127.18.2.el7.x86_64
Operating System - NethServer release 7.8.2003 (final).
I’ve found when my issue occurs but I’m hoping someone can help with why it’s occurring.
When I choose “Prune unreferenced data on” to be Always the backup will not save. I press on the last Edit button which will save and close the backup settings and the settings does not close. No error is given. But when I choose a specific day for “Prune unreferenced data on” then I can save my backup changes.
What does “Prune unreferenced data on” set to always do and why can’t I choose it in Restic backup?
I’ll add in @support_team for input on why adding the purge Always causes my backup job to not be saved when editing.
