NethServer release 7.6.1810 (final)
create a dummy interface as per Dummy Interface (virtual NIC)
the newly created dummy NIC cannot be used, system asks to release the role.
The only workaround I have found to have a virtual nic is to create a new VLAN under the dummy itself an promote the VLAN NIC to green role.
Is it by design or just a bug?
iI will give it a try, thanks
Can you show your ‘diagnostics’ dummy entry?
here’s it
1: lo: <LOOPBACK,UP,LOWER_UP> mtu 65536 qdisc noqueue state UNKNOWN group default qlen 1000
link/loopback 00:00:00:00:00:00 brd 00:00:00:00:00:00
inet 127.0.0.1/8 scope host lo
valid_lft forever preferred_lft forever
inet6 ::1/128 scope host
2: ens18: <BROADCAST,MULTICAST,UP,LOWER_UP> mtu 1500 qdisc pfifo_fast state UP group default qlen 1000
link/ether d2:90:41:fb:fd:85 brd ff:ff:ff:ff:ff:ff
inet 192.168.19.20/24 brd 192.168.19.255 scope global ens18
inet6 fe80::d090:41ff:fefb:fd85/64 scope link
3: dummy0: <BROADCAST,NOARP,UP,LOWER_UP> mtu 1500 qdisc noqueue state UNKNOWN group default qlen 1000
link/ether 10:00:01:02:03:04 brd ff:ff:ff:ff:ff:ff
inet 10.1.2.1/24 brd 10.1.2.255 scope global dummy0
inet6 fe80::1200:1ff:fe02:304/64 scope link
So it does have the correct set MAC address. It is just the Nethserver inner detection that can not cope with dummy interfaces yet.
But what are trying to achieve and within what menu?
I’m trying to have the dummy interfaces setted up as green and the physical one as red.
Nethserver is not working at this moment becasue dummy is not recognized and all I can do is just release its role
This is the important part for you:
So you have to enter the correct IP addresses in your case for green and red, attached to the correct interfaces.
I did it yet… control my posts… about 3 hours ago, the second with image attached. dummy is green but unusable and the physical one is red… both with an IP address
Where, in what menu did you make the screenshots?
What is the output of ‘db networks show’ on the console pls?
db networks show
dummy0=ethernet
ipaddr=10.1.2.1
netmask=255.255.255.0
role=green
ens18=ethernet
FwInBandwidth=
FwOutBandwidth=
bootproto=none
gateway=192.168.19.1
ipaddr=192.168.19.20
role=red
ppp0=xdsl-disabled
AuthType=auto
FwInBandwidth=
FwOutBandwidth=
Password=
name=PPPoE
provider=xDSL provider
role=red
user=
red1=provider
interface=ens18
weight=1
Looks all fine, I assume 192.168.19.x network can reach the internet for it is a private adress. Can you tell a bit more about what exactly is not working?
cannot reach internet because one interface it’s not working
PING 8.8.8.8 (8.8.8.8) 56(84) bytes of data.
— 8.8.8.8 ping statistics —
13 packets transmitted, 0 received, 100% packet loss, time 12000ms
if one interface is not working nethserver only has a limited network functionality… or am I wrong?
But both IP addresses are private addresses, so they will never route to the internet…
no, you are wrong i’m sorry…
from menu diagnostic-> route
default via 192.168.19.1 dev ens18
10.1.2.0/24 dev dummy0 proto kernel scope link src 10.1.2.1
192.168.19.0/24 dev ens18 proto kernel scope link src 192.168.19.20
from another NS working correctly with similar configuration
where I setup a VLAN ( working ) from a dummy not working
that’s the problem I asking help to solve
