Dual mount, duplicated home file stores?
NethServer Version: 7.9
Does this look odd to anyone?
The reason I ask is that this install has a user that uses their home folder ie; user@domain. and when I look at the file system their files (13.74GB) seem to be duplicated in /home/user and in /var/lib/nethserver/home/user looking both in the shell and in the Disk Usage in Cockpit. I’d like to have that extra 13.74GB back if that’s the case.
I checked a few other installs and they’re all mounted at / only.
The home folder is not duplicated, it’s a bind mount, see documentation.
The bind mount was default in new installations for compatibility reasons but it was removed in NS7.5, see github.
