hello
how I can make it work the DPI module…???
hello
You can install ndpi and firewall modules, then you’ll be able to create the desired firewall rules following the instructions in the manual (also in spanish)
Hello to all nets in my nethserver the dpi module is installed but for no reason appears in active services
thank you
On Status > DPI there’s a list of available DPI services and its status.
On Gateway > Firewall rules, when creating a new rule and selecting a Service there’s a non-paginated list of services to select from (e.g. Showing 10 results out of 274) and a search box to find additional services, like the DPI ones.
Thanks for your info and really simple with this guide really use the dpi module
thank you
