Dovecot process limit
NethServer Version: 7.3
Module: Dovecot
I realized that Mail Log
dovecot: master: Warning: service(imap-login): process_limit (400) reached, client connections are being dropped
I increased the value in /etc/dovecot/dovecot.conf.
how is it possible to make the change permanent?
thanks
best regards
The procedure should be
  config setprop dovecot MaxProcesses 800
  signal-event nethserver-mail-server-update || signal-event nethserver-mail2-server-update
Time to update?
Hi Davide,
thanks for the reply, the server is in production, do you think it is appropriate to update it?
Hi @AndreLinux,
I think it’s no problem, I updated all my systems.
Do you have virtualization? So you only have to do a snapshot before, if something doesn’t work you can go back in a few minutes.
