roger65
(Roger Bisson)
November 9, 2021, 3:24pm
#1
HI
i have nethserver 7.9.2009 running with zerotier network on a cloud machine.
its working fine with ad and so on.
First i had openvpn installed then deinstalled it, after deleting all tunnels.
My AD is bridged with one of the zerotier Networks and so i build a bridge with the zerotier network.
After reboot the route looks like this:
and of course, the route won’t work.
When i configure the br0 interface again as green, bridge with zerotier network, then the route is ok.
But after reboot, it’s the same again double entry in the route and non working route.
How can i get rid of this problem?
THX
Roger
roger65
(Roger Bisson)
November 9, 2021, 3:25pm
#2
single route after reconfiguring br0
roger65
(Roger Bisson)
November 9, 2021, 3:42pm
#4
After
signal-event interface-update
it works.
How can i call the signal-event after startup?
mrmarkuz
(Markus Neuberger)
November 10, 2021, 12:14am
#5
Hi and welcome to NethServer Community,
maybe it helps to define the relevant routes manually:
This will not survive a network reconfiguration.
You should use the configuration database as you did with the network.
Adapt the following command:
db routes set 0.0.0.0/0 static Description “default gw” Device eno1 Metric “” Router IP_DEFAULT_GATEWAY
You can apply the configuration with signal-event interface-update.
Warning: you could loose connection in case of mistakes.
