Dolibarr 19.02 to 23.03
Hello Community, i have a question about Dolibarr. I migrate it from the NS7 and update it from Rev. 17.02 to 19.02 what is the last version on the Software Repositories. Is someone able to update it to 23.03 in the Repositories?
Thanks in Advance Hucky
Hello @hucky For this we need to do incremental update from 19 β†’ 20 β†’ 21 β†’ 22 β†’ 23
The update for migration goes by Web but we would need the app updated to 20,21,22,23
Will update the ns8-dolibarr
thank you would be great
Hello, i finished it by myself, i am migrated from NS7 dolibarr 17 to NS8 23.03. so thank your for your message
Thats nice
Any challenges you faced
So that i can have a heads up as i update the ns8-dolibarr later
yes, you must update from your version 19 to 20 to 21to 22 to 23. At my Installation, i migrate from NS7 i had more to update because the Rev. shows me 17 but the database was 14 so i had to go from 14 any version updating to the next and endet with 23.03 what now is working fine.
And if you want to use the email system of dolibar it doesent work to go direct on the ns8 system, u have to put in the
