Dolibarr 15.0.2 - Add external Module?
I would like to know how to install an external module, in my case dolibarr-timesheet, on dolibarr 15.0.2?
Sorry, screenshot only in german:
Hi @fausp
You need to set the right permissions (rw) on the dolibarr folder (apache as user & group).
Then you can simply upload the modules you need via the Web GUI.
Use the folder displayed in your screenshot…
You might need to refresh the Web Gui afterwards (F5), they should show up and be ready if additional configuration is needed. You need to activate each module…
Hi Andy, this is what I get:
grafik
:smile:
OK, I think I got it… I used wget and copied the zip into the folder…
