Hello, I activated an installation of dokuwiki with the farmer module. everything works fine but now I should remove the doku.php from the address. I’ve tried enabling dokuwiki rewrite and it doesn’t seem to work.
Does anyone know how to do?
Thank you
Did you install dokuwiki in a virtualhost or do you use the module?
You may need some apache configuration to make it work, if you used a .htaccess file you may have to enable processing .htaccess files.
https://www.dokuwiki.org/rewrite
