DokuWiki LDAP auth n/a
FYI,
I have tried to select LDAP as auth provider to DokuWiki, but it doesn’t work .
I may have missed a detail somewhere , maybe an FQDN and LDAP “name” mismatch …
Internal auth works fine .
Regards
No issues here, I can switch between internal and LDAP without any issues.
That should not be possible, for you can only select from the LDAP domain providers you created under “Domain and Users”.
