We are starting to polishing things for the NS8 beta 1 release.
Since ChatGPT is again available in Italy, I’ve tried to ask the AI to rewrite a couple of documentation chapter: the intro and the release glossary.
Intro: human
NethServer 8 (NS8) is a GNU/Linux application server designed for small offices and medium enterprises. Applications can be managed from a simple Web user interface.
Under the hood, NS8 is a container orchestrator. It can host different applications on a single machine or spread the load across multiple nodes.
NethServer 8 (NS8), is the evolution of NethServer 7 (NS7).
Get support
You want to know more or look for some help? Check out our great community!
If you’re looking for more technical details, take a look to the developer manual.
Bugs can be discussed and reported inside the community forum. A public issue tracker is available at GitHub.
Intro: ChatGPT:
NethServer 8 (NS8) is an application server based on GNU/Linux, designed specifically for small offices and medium enterprises. It comes with a simple-to-use web interface, allowing for easy management of applications.
Beneath the surface, NS8 serves as a container orchestrator. This means that it is capable of hosting different applications on a single machine, or spreading the load across multiple nodes.
NS8 is the successor to NethServer 7 (NS7).
If you’re looking for more information or need help, our community is a great resource to check out. For technical details, you can refer to the developer manual.
If you come across any bugs, feel free to discuss and report them within the community forum. Alternatively, there is a public issue tracker available on GitHub.
Release glossary: human
Alpha: the software is not thoroughly tested and may not contain all planned features. Do not use this release on production. You can use this release to see what’s coming on the upcoming version. Updates from alpha release to other releases is not supported.
Beta: the software can be considered feature complete but may still contain many known and unknown bugs. Do not use this release on production. You can use this release to test the software before using it on production environments. Updates from beta release to RC and stable are supported but may require manual procedure.
Release Candidate (RC): the software is feature complete, it contains no known bugs and can be promoted to stable if no major issues arise. Updates from RC to stable is supported and should be almost automatic. Use this release on production only if you already have some experience with the software.
Stable: the software can be safely used on production environments.
Release glossary: ChatGPT
The software release cycle includes four stages: Alpha, Beta, Release Candidate (RC), and Stable.
During the Alpha stage, the software is not thoroughly tested and may not include all planned features. This release is not suitable for production environments. However, it can be used to preview what’s coming in the upcoming version. Please note that updates from an Alpha release to other releases are not supported.
The Beta stage indicates that the software is feature complete, but it may still contain many known and unknown bugs. This release should not be used on production environments. However, it can be used to test the software before deploying it to production. Updates from a Beta release to an RC or Stable release are supported but may require a manual procedure.
During the Release Candidate (RC) stage, the software is feature complete, and it contains no known bugs. If no major issues arise, it can be promoted to Stable. Updates from an RC release to a Stable release are supported and should be almost automatic. However, if you’re new to the software, it’s best to use it on production only if you already have some experience with it.
The Stable release is the most reliable and safe to use on production environments. It has been thoroughly tested and is considered to be free of major bugs.
Which version is better? Human or AI?
As non-native English speaker, I’m not sure which I like more
