NethServer Version: 7.9.2009 (final)
Module: nethserver-docker
I installed nethserver-docker using the Software Center. Thereafter I followed the instructions shown here
https://docs.nethserver.org/en/v7/docker.html
but docker didn’t start.
The outputs are:
[root@nethserver ~]# systemctl status docker
● docker.service - Docker Application Container Engine
Loaded: loaded (/usr/lib/systemd/system/docker.service; enabled; vendor preset: disabled)
Drop-In: /etc/systemd/system/docker.service.d
└─nethserver.conf
Active: failed (Result: start-limit) since Sun 2021-11-14 12:17:53 CET; 34min ago
Docs: https://docs.docker.com
Process: 19909 ExecStart=/usr/bin/dockerd --config-file=/etc/docker/docker.conf (code=exited, status=1/FAILURE)
Main PID: 19909 (code=exited, status=1/FAILURE)
Nov 14 12:17:51 nethserver systemd[1]: docker.service: main process exited, code=exited, status=1/FAILURE
Nov 14 12:17:51 nethserver systemd[1]: Failed to start Docker Application Container Engine.
Nov 14 12:17:51 nethserver systemd[1]: Unit docker.service entered failed state.
Nov 14 12:17:51 nethserver systemd[1]: docker.service failed.
Nov 14 12:17:53 nethserver systemd[1]: docker.service holdoff time over, scheduling restart.
Nov 14 12:17:53 nethserver systemd[1]: Stopped Docker Application Container Engine.
Nov 14 12:17:53 nethserver systemd[1]: start request repeated too quickly for docker.service
Nov 14 12:17:53 nethserver systemd[1]: Failed to start Docker Application Container Engine.
Nov 14 12:17:53 nethserver systemd[1]: Unit docker.service entered failed state.
Nov 14 12:17:53 nethserver systemd[1]: docker.service failed.
[root@nethserver ~]# systemctl restart docker
Job for docker.service failed because the control process exited with error code. See "systemctl status docker.service" and "journalctl -xe" for details.
[root@nethserver ~]# docker ps
Cannot connect to the Docker daemon at unix:///var/run/docker.sock. Is the docker daemon running?
The /var/log/docker/docker.log says:
Nov 14 12:57:58 nethserver dockerd: time="2021-11-14T12:57:58.494179756+01:00" level=info msg="ClientConn switching balancer to \"pick_first\"" module=grpc
Nov 14 12:57:58 nethserver dockerd: time="2021-11-14T12:57:58.497726753+01:00" level=info msg="parsed scheme: \"unix\"" module=grpc
Nov 14 12:57:58 nethserver dockerd: time="2021-11-14T12:57:58.497752083+01:00" level=info msg="scheme \"unix\" not registered, fallback to default scheme" module=grpc
Nov 14 12:57:58 nethserver dockerd: time="2021-11-14T12:57:58.497772953+01:00" level=info msg="ccResolverWrapper: sending update to cc: {[{unix:///run/containerd/containerd.sock
<nil> 0 <nil>}] <nil> <nil>}" module=grpc
Nov 14 12:57:58 nethserver dockerd: time="2021-11-14T12:57:58.497782444+01:00" level=info msg="ClientConn switching balancer to \"pick_first\"" module=grpc
Nov 14 12:57:58 nethserver dockerd: time="2021-11-14T12:57:58.499061636+01:00" level=warning msg="[graphdriver] WARNING: the devicemapper storage-driver is deprecated, and will b
e removed in a future release"
Nov 14 12:57:58 nethserver dockerd: time="2021-11-14T12:57:58.550668194+01:00" level=error msg="File descriptor 3 (socket:[43434]) leaked on pvdisplay invocation. Parent PID 2268
1: /usr/bin/dockerd\nFile descriptor 13 (/dev/mapper/control) leaked on pvdisplay invocation. Parent PID 22681: /usr/bin/dockerd\n Failed to find physical volume \"/dev/sda\".\n
" error="exit status 5"
Nov 14 12:57:58 nethserver dockerd: failed to start daemon: error initializing graphdriver: File descriptor 3 (socket:[43434]) leaked on pvcreate invocation. Parent PID 22681: /u
sr/bin/dockerd
Nov 14 12:57:58 nethserver dockerd: File descriptor 13 (/dev/mapper/control) leaked on pvcreate invocation. Parent PID 22681: /usr/bin/dockerd
Nov 14 12:57:58 nethserver dockerd: Device /dev/sda excluded by a filter.
Nov 14 12:57:58 nethserver dockerd: : exit status 5
Nov 14 12:58:00 nethserver dockerd: time="2021-11-14T12:58:00.709553596+01:00" level=info msg="Starting up"
Nov 14 12:58:00 nethserver dockerd: time="2021-11-14T12:58:00.712810003+01:00" level=info msg="parsed scheme: \"unix\"" module=grpc
Nov 14 12:58:00 nethserver dockerd: time="2021-11-14T12:58:00.712835063+01:00" level=info msg="scheme \"unix\" not registered, fallback to default scheme" module=grpc
Nov 14 12:58:00 nethserver dockerd: time="2021-11-14T12:58:00.712859622+01:00" level=info msg="ccResolverWrapper: sending update to cc: {[{unix:///run/containerd/containerd.sock
Nov 14 12:58:00 nethserver dockerd: time="2021-11-14T12:58:00.712873773+01:00" level=info msg="ClientConn switching balancer to \"pick_first\"" module=grpc
Nov 14 12:58:00 nethserver dockerd: time="2021-11-14T12:58:00.716769181+01:00" level=info msg="parsed scheme: \"unix\"" module=grpc
Nov 14 12:58:00 nethserver dockerd: time="2021-11-14T12:58:00.716788771+01:00" level=info msg="scheme \"unix\" not registered, fallback to default scheme" module=grpc
Nov 14 12:58:00 nethserver dockerd: time="2021-11-14T12:58:00.716805811+01:00" level=info msg="ccResolverWrapper: sending update to cc: {[{unix:///run/containerd/containerd.sock
Nov 14 12:58:00 nethserver dockerd: time="2021-11-14T12:58:00.716815051+01:00" level=info msg="ClientConn switching balancer to \"pick_first\"" module=grpc
Nov 14 12:58:00 nethserver dockerd: time="2021-11-14T12:58:00.717538662+01:00" level=warning msg="[graphdriver] WARNING: the devicemapper storage-driver is deprecated, and will b
Nov 14 12:58:00 nethserver dockerd: time="2021-11-14T12:58:00.772545627+01:00" level=error msg="File descriptor 3 (socket:[43434]) leaked on pvdisplay invocation. Parent PID 2269
8: /usr/bin/dockerd\nFile descriptor 13 (/dev/mapper/control) leaked on pvdisplay invocation. Parent PID 22698: /usr/bin/dockerd\n Failed to find physical volume \"/dev/sda\".\n
Nov 14 12:58:00 nethserver dockerd: failed to start daemon: error initializing graphdriver: File descriptor 3 (socket:[43434]) leaked on pvcreate invocation. Parent PID 22698: /u
sr/bin/dockerd
Nov 14 12:58:00 nethserver dockerd: File descriptor 13 (/dev/mapper/control) leaked on pvcreate invocation. Parent PID 22698: /usr/bin/dockerd
Nov 14 12:58:00 nethserver dockerd: Device /dev/sda excluded by a filter.
Nov 14 12:58:00 nethserver dockerd: : exit status 5
Nov 14 12:58:02 nethserver dockerd: time="2021-11-14T12:58:02.957759508+01:00" level=info msg="Starting up"
Nov 14 12:58:02 nethserver dockerd: time="2021-11-14T12:58:02.959515742+01:00" level=info msg="parsed scheme: \"unix\"" module=grpc
Nov 14 12:58:02 nethserver dockerd: time="2021-11-14T12:58:02.959562302+01:00" level=info msg="scheme \"unix\" not registered, fallback to default scheme" module=grpc
Nov 14 12:58:02 nethserver dockerd: time="2021-11-14T12:58:02.959594623+01:00" level=info msg="ccResolverWrapper: sending update to cc: {[{unix:///run/containerd/containerd.sock
Nov 14 12:58:02 nethserver dockerd: time="2021-11-14T12:58:02.959626212+01:00" level=info msg="ClientConn switching balancer to \"pick_first\"" module=grpc
Nov 14 12:58:02 nethserver dockerd: time="2021-11-14T12:58:02.963320210+01:00" level=info msg="parsed scheme: \"unix\"" module=grpc
Nov 14 12:58:02 nethserver dockerd: time="2021-11-14T12:58:02.963356220+01:00" level=info msg="scheme \"unix\" not registered, fallback to default scheme" module=grpc
Nov 14 12:58:02 nethserver dockerd: time="2021-11-14T12:58:02.963399820+01:00" level=info msg="ccResolverWrapper: sending update to cc: {[{unix:///run/containerd/containerd.sock
Nov 14 12:58:02 nethserver dockerd: time="2021-11-14T12:58:02.963417410+01:00" level=info msg="ClientConn switching balancer to \"pick_first\"" module=grpc
Nov 14 12:58:02 nethserver dockerd: time="2021-11-14T12:58:02.969030202+01:00" level=warning msg="[graphdriver] WARNING: the devicemapper storage-driver is deprecated, and will b
Nov 14 12:58:03 nethserver dockerd: time="2021-11-14T12:58:03.023517456+01:00" level=error msg="File descriptor 3 (socket:[43434]) leaked on pvdisplay invocation. Parent PID 2271
7: /usr/bin/dockerd\nFile descriptor 13 (/dev/mapper/control) leaked on pvdisplay invocation. Parent PID 22717: /usr/bin/dockerd\n Failed to find physical volume \"/dev/sda\".\n
Nov 14 12:58:03 nethserver dockerd: failed to start daemon: error initializing graphdriver: File descriptor 3 (socket:[43434]) leaked on pvcreate invocation. Parent PID 22717: /u
sr/bin/dockerd
Nov 14 12:58:03 nethserver dockerd: File descriptor 13 (/dev/mapper/control) leaked on pvcreate invocation. Parent PID 22717: /usr/bin/dockerd
Nov 14 12:58:03 nethserver dockerd: Device /dev/sda excluded by a filter.
Nov 14 12:58:03 nethserver dockerd: : exit status 5
I think the issue shown in the logfile
is the cause of my problem to start docker, but to be honestly I dont know why?
[root@nethserver ~]# fdisk -l /dev/sda
Disk /dev/sda: 34.4 GB, 34359738368 bytes, 67108864 sectors
Units = sectors of 1 * 512 = 512 bytes
Sector size (logical/physical): 512 bytes / 512 bytes
I/O size (minimum/optimal): 512 bytes / 512 bytes
Disk label type: dos
Disk identifier: 0x000e8405
Device Boot Start End Blocks Id System
/dev/sda1 2048 2097151 1047552 83 Linux
/dev/sda2 * 2097152 4194303 1048576 83 Linux
/dev/sda3 4194304 27492351 11649024 83 Linux
/dev/sda4 27492352 67108863 19808256 5 Extended
/dev/sda5 27496448 35622911 4063232 82 Linux swap / Solaris
Does anybody know what’s wrong here?
Do I need a separate partition for docker?
Kind Regards
Pete
