When i setup dns. dnsmasq cache bad - empty request from server which is faster.
I find solution for this but is not permanent because is regenerated every time when i change dnsmasq settings in panel
And i have question where and how i can add one line look like :
This is not client problem i check. And dig aprove this.
Client station ask directly nethserver which cache result.
End if i edit manualy dnmasq.conf all worked fine this exclude client problem
This is specific example - this is small bug or lack confguration, becouse when a sent request
host1.subdomain.tld and DNS1 send empty response dnsmasq should be wait for next upstream server but his don’t do that and write cache. In this moment all cliens have bad response. This strange because in config dnsmasq have default
all-servers
And with this option should wait for response all servers. And if all servers return empty response write to cache. And cached more complex result…
