DNSMasq - Default Gateway?
Hi All,
I am looking for a way to setup the Default Gateway IP under the DNSMasq-Module/App
On the Client it shows the NS8-IP but I need to setup the Router-IP…
How can I do it?
Create a file /var/lib/nethserver/dnsmasq1/state/dnsmasq.d/99custom.conf with following content:
dhcp-option=option:router,192.168.0.1
Restart service:
systemctl restart dnsmasq1
See also DNSMasq — NS8 documentation
Thank you Markus, this works!
