For my purposes, I need to change dnsmasq.conf but after some updates or when I change the IP address of the Internet interface, dnsmasq.conf does not keep what I changed.
Is it possible to keep the changes?
I need that Nethserver redirects PXE requests to another server (Opsi with Clonezilla).
Here I change the dnsmasq.conf:
tftp-root=/var/lib/tftpboot
dhcp-option=66,“192.168.1.245”
dhcp-boot=/tftpboot/linux/pxelinux.0,boothost,“192.168.1.245”
After changing the IP address or web interface updates:
enable-tftp
dhcp-option=66,“192.168.1.1”
Is an interface under development to declare another server (next server)? Something like what is possible in, sorry for the comparaison, Zentyal:
I’m sure it will be useful to other people.
Thks a lot.
configuration it’s overwritten by template-system.
You can find more information inside the developer manual as correctly pointed out by Stefano.
But we already have plans to extend the web interface. See http://dev.nethserver.org/issues/3036.
Maybe you can suggest some common options we can display inside the web interface?
In the meanwhile, you can achieve your goal using a template-custom:
yep write your custom-template, or add a template.
the difference is tiny, a custom-template is there to rewritte an official template from a rpm, a template can be used if the developer has let some place/right to add your modifications.
