I have setup Nethserver on a number of installs, but on this recent one I am receiving the following. The status shows DKIM record is not matching and the IP reverse exit code not zero.
Domain is through Godaddy. I have paste the record data for DKIM in DNS as a TXT.
It looks like it is correct, so I am unaware of why there is an error.
The reverse DNS would need to be set up with your ISP–the folks who own the IP address your Neth server is using. Mine is running on a VPS, so my VPS host has the entry. But “exit code not zero” is a pretty poor error message.
