I’m noticing a small problem with the display of network interfaces on the dashboard of my server. It has three NICs, only one of which is active. When I browse to the dashboard, it defaults to the alphabetically-first one, which isn’t the active one:
That really isn’t a problem; I can just click the tab for the interface I want. But when I do that, I get:
It looks like this pane should resize to accommodate the information it contains, but it doesn’t do that. Is there a fix, or is this a bug?
