carsten
(Carsten Härle)
1
NethServer Version: 7.9.2009
The documentation says, that the firewall policies can be displayed in the rules page, but this page is empty in my installation:
“To display the list of active policies click on the Policies button inside the Rules page.”
https://docs.nethserver.org/en/v7/firewall.html#policy
You can see them in Cockpit > Firewall > Rules > Policies.
carsten
(Carsten Härle)
3
No policies button there.
This is a bug. If no rules are present, policies button is not showed.
I will update you asap.
giacomo
(Giacomo Sanchietti)
7
@federico.ballarini did a wonderful job and implemented this feature!
@carsten do you want to give it a try?
Remember to install the packages from testing repository
carsten
(Carsten Härle)
8
Yes it works. Thanks. Should I also comment in github?
giacomo
9
If you already have the account, it would be wonderful
Otherwise, no problem, I will do it for you.
Thank you for the testing!
