Dhcp gateway error
dhcp
vps
(Nitram Oneito) #1
NethServer Version: latest
Module: Network
I have been experiencing a challenge that has so far been repetitive.
in some vps providers, After installing nethserver, the network is default to DHCP, which alwys gives me an warning on the screen.
so I have to change to a static .
The challenge comes when I try to configure the static ip, at the section of gateway, sometimes I would use if ip is 80.12.14.25 I would set the gateway to 80.12.14.1 and it would work, in some instances it would not.
Even if I do a route -n in command line, I get the gateway, when I use it, it does not work.
The challenge I gte biggest, is that I get locked out of the server, I can not ping to the server, and even if I og in via vnc, I can not ping outside. why does this keep happening,
so far my solutions has been to rebuild the server, if the provider does not offer image backups, or restore from a restore point I created.
is it an issue with nethserver, with my configurations, or with the provider?
(Michael Kicks) #2
@oneitonitram which network zone are you talking about? Red? Green? Orange?
(Nitram Oneito) #3
It is on the green network mostly
(Markus Neuberger) #4
It should work if you set the same static IP you got from DHCP.
When you only have a green interface the gateway needs to be entered on the green interface. If you have an additional red interface the gateway needs to be entered there.
(Nitram Oneito) #5
I have tried to enter the same ip address as the server, it refues,
is there a problem if nethserver operates with dhcp instead of static ip, on a vps
(Markus Neuberger) #6
I am used to static IPs for servers but if the IP doesn’t change there should be no problem on a VPS but I never tried.
(Nitram Oneito) #7
its ok, its the warning which I cant shut o
ff
(Markus Neuberger) #8
These messages are in /etc/nethserver/todos.d/.
IIRC it’s enough to chmod -x /etc/nethserver/todos.d/10green-dhcp
http://docs.nethserver.org/projects/nethserver-devel/en/v7/todos_api.html
(Nitram Oneito) #9
Thank you.
I really am learning a lot with regards to nethserver. its a system
in a short while ill be guru
I was wondering, where are the future development roadmaps listed?
(Markus Neuberger) #10
You’re welcome.
Here it is the roadmap:
(Michael Kicks) #11
IMHO, use a public address as Green zone interface could not be best choice for security…
At least… If you don’t change the firewall default rules.
