Looking to make a contrib docker based with an application that supply a launcher to create the container, I have some issue to talk. The name of the contrib I aim is discourse
I can create the container with a stock docker, use a linux socket to communicate with apache, and therefore get rid of any network issue. My issue comes when I try to use nethserver-docker on the @mrmarkuz and to be compatible
It seems there is not the default network of docker called docker0, the launcher stop at this point
[root@ns7loc15 ~]# docker ps
[root@ns7loc15 ~]# docker network ls
NETWORK ID NAME DRIVER SCOPE
0526a5665e09 aqua bridge local
0acaaae75611 host host local
05a0bf1a8ccf none null local
[root@ns7loc15 ~]# ip a
1: lo: <LOOPBACK,UP,LOWER_UP> mtu 65536 qdisc noqueue state UNKNOWN group default qlen 1000
link/loopback 00:00:00:00:00:00 brd 00:00:00:00:00:00
inet 127.0.0.1/8 scope host lo
valid_lft forever preferred_lft forever
inet6 ::1/128 scope host
2: eth0: <BROADCAST,MULTICAST,UP,LOWER_UP> mtu 1500 qdisc pfifo_fast state UP group default qlen 1000
link/ether 08:00:27:72:ad:38 brd ff:ff:ff:ff:ff:ff
inet 192.168.56.16/24 brd 192.168.56.255 scope global eth0
inet6 fe80::a00:27ff:fe72:ad38/64 scope link
3: enp0s3: <BROADCAST,MULTICAST,UP,LOWER_UP> mtu 1500 qdisc pfifo_fast state UP group default qlen 1000
link/ether 08:00:27:14:31:5f brd ff:ff:ff:ff:ff:ff
inet 10.0.2.15/24 brd 10.0.2.255 scope global dynamic enp0s3
valid_lft 85762sec preferred_lft 85762sec
inet6 fe80::a00:27ff:fe14:315f/64 scope link
4: aqua0: <NO-CARRIER,BROADCAST,MULTICAST,UP> mtu 1500 qdisc noqueue state DOWN group default
link/ether 02:42:0c:b8:2c:f4 brd ff:ff:ff:ff:ff:ff
inet 172.28.0.1/16 brd 172.28.255.255 scope global aqua0
inet6 fe80::42:cff:feb8:2cf4/64 scope link
this is not good because the launcher of discourse try to create on this default interface with the default bridge of docker.
I could remove the bridge none in /etc/docker/docker.conf, this time the bridge is created but I have some networking issue on the default bridge
[root@ns7loc15 discourse]# docker run busybox ping -c 1 8.8.4.4
PING 8.8.4.4 (8.8.4.4): 56 data bytes
--- 8.8.4.4 ping statistics ---
1 packets transmitted, 0 packets received, 100% packet loss
The launcher stops because it cannot retrieve some files remotely. Obviously everything seems to work on acqua network
[root@ns7loc15 discourse]# docker run --net=aqua busybox nslookup google.com
Server: 127.0.0.11
Address: 127.0.0.11:53
Non-authoritative answer:
Address: 2a00:1450:4007:805::200e
*** Can't find google.com: No answer
[root@ns7loc15 discourse]# docker run --net=aqua busybox ping -c 1 8.8.4.4
64 bytes from 8.8.4.4: seq=0 ttl=61 time=19.222 ms
1 packets transmitted, 1 packets received, 0% packet loss
round-trip min/avg/max = 19.222/19.222/19.222 ms
I wonder if it is a good idea to have a specific acqua network and remove the docker default one ?
