Hi all,
I’m installing 7.8 at the moment and it needs some time for downloading rpm, it would be nice to show details of an update job, like 124 MB from 324 MB downloaded and after downloading which libs are installed at the moment.
Hi all,
I don’t know if it’s so easy to collect those data in realtime.
If you do a yum from terminal you have a little bit more information, if we can have this information at the gui it would be enough. It’s only to get not nervous if nothing happens
Personally I prefer to do the update throught terminal/SSH. Then you get more updates than shown in the webgui…
I thought the update button at the gui triggers a yum update.
I should say: update information. The amount of updates is the same
