Delete an e-smith property
(Stéphane de Labrusse) #1
I’m doing a migrate fragment like this way @dev_team
    # We want to migrate the IMAPLoginFieldName
    # property to CustomEmailField
    use esmith::ConfigDB;
    my $db = esmith::ConfigDB->open;
    my $sogod = $db->get('sogod');
    my $CustomEmailField = $sogod->prop('IMAPLoginFieldName');
    if ($CustomEmailField) {
        $db->set_prop('sogod','CustomEmailField',$CustomEmailField);
        $sogod->delete_prop('IMAPLoginFieldName');
could it be possible (I assume that I need to do a feature request)
    my $CustomEmailField = $db->get_prop('sogod','IMAPLoginFieldName');
        $db->del_prop('sogod','IMAPLoginFieldName');
it is quicker :frowning:
(Giacomo Sanchietti) #2
I always liked this non-existing api! :smiley:
I don’t know if does it worth to implement, but in your case you can also use this code:
 $db->get_prop_and_delete('sogod','IMAPLoginFieldName');
(Stéphane de Labrusse) #3
thank for sharing it, indeed it is probably faster
I’m reading again the api :blush:
