Is it possible to set a dedicated destination folder for Imapsync? It would help to better distinguish old and new mails.
Why can’t you distinguish old/new mails and what do you want to achieve? Maybe there’s a better solution than imapsync…it’s thought for mail migrations.
I think it’s possible with following option but I didn’t test. It’s not included in the UI AFAIK.
--subfolder2 str : Syncs the whole host1 folders hierarchy under the
host2 folder named str.
It does it internally by adding three
--regextrans2 options before all others.
Add --debug to see what's really going on.
Thank you. The function is known to me and I do this also as mail*root, nevertheless I find nicer to use such function by Gui.
I changed the topic category to feature request.
