Hello to all!
In the dashboard there is a Hardware widget. I’ve been looking through the docs and in the forums and haven’t found an answer yet, but my question is this. In the Hardware widget, how would I edit the text that is displayed for Vendor and Model?
That information is retrieved from the hardware: you can’t edit it. To change it you have to replace the hardware!
Why do you want to edit it? Is it not correct?
It’s not correct.
I’ve checked the bios settings. I was just trying to see where else I could correct it or if I could manually update it myself.
Here’s a little explanation:
