Dashboard locations for a couple items
I thought I had found these in another box earlier that I was testing out using NS8, but I can not find it in the current install I am working with, So I have the following questions…
I has a couple of items I was curious on-
Shutdown / Restart
  1. Where do I shutdown or restart NS8 in dashboard. Is there a place on the dashboard that I am not seeing?
The following is for NS8 Core IP, subnet mask, and gateway. (migrating to another network)
DHCP or STATIC
2. Location to change IP from DHCP to STATIC in dashboard.
IP Address
3. Location to change IP address to a specific IP address in dashboard.
Subnet mask
4. Location to change subnet mask in dashboard.
Gateway
5. Location to change gateway in dashboard.
Thanks,
-SF-
If memory serves me well, neither of those options are available. You have to resort to OS or cockpit.
@Shadowfire , @dnutan
I can and will confirm this.
The underlying OS handles this, not NS8!
Seems this would be a useful feature for ease of Admin administration purposes. Is there a reason like security that they didn’t include it in the NS8 core? or is it because the underlying OS could be different - such as rocky or debain?
@Shadowfire
One reason:
Debian uses apt, All RHEL clones (Rocky, Alma, usw) use dmf (yum).
but this reason can be circumvented by a simple OS query.
Different repos
But same solution as above could be implemented.
Other reasons I’m not aware of…
It’s possible it will come in a future release.
For the moment, Cockpit can be installed, as Marc suggests above.
This is the suggested workaround for the moment.
On the other hand, maintaining base OS updates via script is a viable option when maintaining several installations / sites - when all are running the same basis OS.
Still, I do agree with you, especially for single site users, having a simple view, eg on Cluster Status (or nodes) would simplify administration a lot.
Something along the lines of:
Base OS updates available:
and a button linking to “Do Base OS update now”.
And for any contemplating a migration of a multi node cluster to a paid subscription, this would require (at the moment) migrating all nodes to Rocky. The used OS is AFAIK, not visible in NS8 at the moment. This should be visible on the nodes page. This way, a node per node migration, becomes a bit more streamlined and visible.
Yes, I appreciate the feedback on this. I guess I was hoping that the Dashboard for NS8 would allow for this as its one less location to administrate. One less user and password to deal with outside of NS8.
Base off a standalone install and multi-node I think they both could include a page that listed each node. That listing would allow buttons or the capacity to allow you to power on (WOL) / restart, power off, change ip, subnet, gateway, and base OS updates.
This could once again save time for the administrator with network topology changes, network migration, adjustments, upgrades and update.
-SF-
WOL would not work for multi-site environments, but for bare metal local installs could have it’s benefits.
Proxmox, for example; does not support WOL.
And as WOL only works on the local LAN, this would have no benefits for a real multi-site setup.
It looks like Proxmox might work, based off the following page.
https://pve.proxmox.com/wiki/Proxmox_Node_Management
https://www.reddit.com/r/Proxmox/comments/13blw5x/wake_on_lan_not_working/
You just might need to add custom command under that node in NS8 page setup to do so. (just speculating of course) But I would be surprised if it wasn’t possible if all the cards are there.
-SF-
There is custom code for Proxmox, using the firewall to intercept the magic packet, and piplining that to the command turning on VMs…
It works.
But it’s not officially supported.
:frowning:
(And probably not quite update / upgrade safe either).
Ah. I see Well… that’s why we have the dev’s who code the impossible :rofl: and make it possible.
And all this time I thought that’s what the left hand is for!
:slight_smile:
