Customize roundcube webmail
NethServer Version: 7.3
Hy to all
i wont customize the rourcube home page with logo and business description?
i have find this https://www.howtoforge.com/community/threads/how-do-i-change-the-roundcube-logo-to-my-own.73836/
but I do not find the roudcube configuration files
please give me info on how to customize the webmail?
Hi @gperna,
we already talked about this in another thread: Nethserver 7 Let’s Encrypt, redirect webgui, plugin responsive roundcube webmail - #4 by gperna
/etc/roundcubemail/config.inc.php
If you change config files do it via the template system:
http://docs.nethserver.org/projects/nethserver-devel/en/v7/templates.html
So you may create /etc/e-smith/templates-custom/etc/roundcubemail/config.inc.php/91MYCHANGES and put your config changes in this file.
$config['skin_logo'] = /usr/share/roundcubemail/mylogo.png;
Then expand the template to write it to the system config files
expand-template /etc/roundcubemail/config.inc.php
Thanks Markus for you replay,
but i not undstend, i new fot nethserver.
but can I proceed without editing the template? I would just like to modify the configuration files in /etc/roundcubemail/config.inc.php
could you give me some extra info?
thank you
Hi @gperna ,
Yes, you can. But if the Roundcube will be updated, the config file from the default location will be rewritten to the default values so, the change will be lost.
The solution given by @mrmarkuz , will avoid that because the custom template will override the default configuration :
" If the templates-custom entry is a file, rather than a directory, it completely overrides the standard template."
Gabriel
thanks Markus for you repaly,
i have do:
  1. create /etc/e-smith/templates-custom/etc/roundcubemail/config.inc.php/91MYCHANGES_WEBMAIL
  2. copied the file mylogo in to dir usr/share/roundcubemail/skins/larry/images/my_logo.png
  3. add the this $config[‘skin_logo’] = usr/share/roundcubemail/skins/larry/images/mylogo_logo.png; in the template 91MYCHANGES_WEBMAIL
  4. expand the template expand-template /etc/roundcubemail/config.inc.php
but not load the logo, see attached img
thanks
If you just want to change the logo you may just replace the roundcube_logo.png.
Even if the logo is /usr/share/roundcubemail/skins/larry/images/testlogo.png you must not use the full path. This worked for me:
$config['skin_logo'] = '/images/testlogo.png';
ok,
thanks i have insert the path correct and is it work.
but if I wanted to change the background and other still images of the home page?
if I wanted to change the phrase “Roundcube Webmail” under the login button?
thanks
Please read here:
http://www.roundcubeforum.net/index.php?topic=1606.0
Or here:
https://github.com/roundcube/roundcubemail/wiki/Configuration
