I have just moved from Arch Linux to NethServer. I am having a strange issue that I can’t figure out on my own reguarding a virtualhost file.
I have my blade server setup with my domain and several subdomains. Everything is working as it should. I installed Emby Media Server manually, and have been trying to get it set up on the subdomain emby.triggeredstudios.com.
When I use the same virtualhost config as I was in Arch, works, but it also breaks the Nextcloud and SOGo pages, and I can access emby even on my unused subdomains that I haven’t added to any virtualhost file yet. My desired behavior is that I only want it to be accessible via emby.triggeredstudios.com.
Here is my exact virtualhost file:
<VirtualHost *:80>
ServerName emby.triggeredstudios.com
RewriteEngine on
RewriteCond %{SERVER_NAME} =emby.triggeredstudios.com
RewriteRule ^ https://%{SERVER_NAME}%{REQUEST_URI} [END,QSA,R=permanent]
</VirtualHost>
<VirtualHost *:443>
<proxy *>
AddDefaultCharset off
Order Allow,Deny
Allow from all
</proxy>
ProxyRequests Off
ProxyPreserveHost On
ProxyPass "/embywebsocket" "ws://127.0.0.1:8096/embywebsocket"
ProxyPassReverse "/embywebsocket" "ws://127.0.0.1:8096/embywebsocket"
ProxyPass "/" "http://127.0.0.1:8096/"
ProxyPassReverse "/" "http://127.0.0.1:8096/"
SSLEngine on
SSLCertificateFile /etc/pki/tls/certs/localhost.crt
SSLCertificateKeyFile /etc/pki/tls/private/localhost.key
</VirtualHost>
NethServer Version: 7.4.1708
Module: nethserver-httpd
