I installed NethServer to serve as AD, file sharing and print server (CUPS), but when trying to send a print job the following error appears: credentials are required to print.
I already tried to comment out the AuthType line in the printers.conf file, and it didn’t work either.
Help me please.
I’m having trouble authenticating a user created on nethserver for the print and shared folder services. nethserver does not recognize users and passwords, but I can authenticate via AD with the same users. Example: if you try to access a shared folder you get an authentication error. The same goes for printing.
