NethServer Version: 7.9
Module: Crontab
I want to run a curl command from corntab but get the following error.
Is there an easy way to solve this? Or should I create a script?
Issuing this command from SSH prompt works.
Thanks
John
Module: Crontab
Thanks
John
I can’t see the whole command in the screenshot, maybe there are “problematic” characters?
Maybe it’s possible to put the command between quotation marks " but a script should work in any case.
