france
(Francesco)
July 29, 2022, 2:55pm
1
Hello everyone, after installing a version of nextcloud, everything seems to work but I get this email message
Subject: Cron apache@netsan /usr/bin/scl enable rh-php73 – php -d memory_limit=512M -d apc.enable_cli=1 -f /usr/share/nextcloud/cron.php
Exception: Not installed in /usr/share/nextcloud/lib/base.php:277
Stack trace:
#0 /usr/share/nextcloud/lib/base.php(649): OC::checkInstalled(Object(OC\SystemConfig))
#1 /usr/share/nextcloud/lib/base.php(1089): OC::init()
#2 /usr/share/nextcloud/cron.php(43): require_once(’/usr/share/next…’)
#3 {main}
mrmarkuz
(Markus Neuberger)
July 31, 2022, 8:33pm
2
Was it a one time error?
Did you install via Software Center?
You could check the cron command on CLI:
sudo -u apache /usr/bin/scl enable rh-php73 -- php -d memory_limit=512M -d apc.enable_cli=1 -f /usr/share/nextcloud/cron.php
france
(Francesco)
August 1, 2022, 4:31am
3
Hi Mark, thank you for replying. I monitored the server, it seems that it generated this error via email only once, as you suggested by running that command from cli, I don’t read any console errors. I will keep the server monitored. Thank you.
Also yes, I installed via software center “nextcloud”.
