Creating Web UI module Documentation
I am currently diving into adapting the web-ui-interface with own configuration pages and i’ve made my way through the doc:
http://docs.nethserver.org/projects/nethserver-devel/en/v7/create_interface_module.html
I’ve found some flaws in the code examples and corrected them in the fork:
I hope the fork does not cause any trouble?! (It was my first one…)
I would like to ask somebody to review this and, if correct, to merge this with the original repository !
Greetings
Björn
@davidep could you please review @smutje1179’s job?
As usual, to start a review a pull request is needed.
Hello Davide !
I’m not sure what do you require. Could you please specify it…
Greeting
Björn
In github if you have cloned a repository and you want to modify something, once you have committed inside your banch/repository you can make a pull request
https://help.github.com/en/articles/about-pull-requests
https://help.github.com/en/articles/creating-a-pull-request
Ok i hope this works !
Greetings
