NethServer Version: NethServer release 7.8.2003 (final)
Module: Network, Firewall, DHCP
for two days I have been trying to configure my network card with 4 ports.
The following is present
Server:
Lan 1: 10.0.1.10
Net: 10.0.1.0/24
Lan 2: 10.0.2.10
Net: 10.0.2.0/24
Lan 3: 10.0.3.10
Net: 10.0.3.0/24
Lan 4: 10.0.4.10
Net: 10.0.4.0/24
Info: 1 Network Card with 4 Lan ports.
Port 5 (from the mainboard) will be used later for the WAN port. (Red)
Lan 5: DHCP
Gateway: 10.0.1.1 (Inet Router).
DNS: 10.0.1.10
DHCP: Lan1: Area 10.0.1.20 - 10.0.1.250
Lan 2: Area 10.0.2.20 - 10.0.2.250
Lan 3: Area 10.0.3.20 - 10.0.3.250
Lan 4: Area 10.0.4.20 - 10.0.4.250
Gateway for Lan 1 - Lan 4 == 10.0.1.1 (address 10.0.1.10 was also tested)
I have tried many settings, but the ping does not work from network to network.
Question:
Access to the Internet only works from Lan 1 (same Subnet like Router?). What do I have to do so that I can also access the Internet from the other networks?
This also applies to connections from Lan1 to Lan2 etc.
DHCP Example for Lan 2:
Thanks for Help
Nicky
