Create folders and subfolders
Good morning, file server can I create folders and subfolders?
ESTRUTURAS
Did you try? And what happened?
All depends if your account has permission to write in the share.
I wanted to know if the nethserver file server, when creating a folder, had the option to create a folder structure instead of creating folders by folder.
Hi @tiagusamaral
As a File-Server, NethServer can create a Share, not folders or subfolders.
The straigth answer for your question is no.
However, after creating the share (as @Andy_Wismer indicated) you can use other tools like TotalCommander to replicate folder structure from your existing windows share to a NethServer share.
Or you can write your own script in Windows to create in automated way the folder structure you need in every share…
Or Robocopy! Should have a folder structure replicate option among several others…
No NethServer, vc cria a estrutura de compartilhamento, tudo fica armazenado dentro do /var/lib/nethserver/ibay.
Pelo seu print, dá a entender que vc quer criar o Diretório Departamentos e depois os compartilhamentos, se for isso mesmo, no Nethserver não funciona assim.
Would you please try again, but in english?
I don’t understand portuguese (or brazilian… i cannot distinguish them)
