Hi all,
I made a new document on Zammad.
● Cours NethServer-201-11: Zammad
https://www.micronator.org/affaires/produit/nethserver-201-cahier-11_zammad/
● Some chapters:
Initial Config, First Steps, Test Ticket, New Ticket, Updates, Daily Backup with a Cron Job, Restoration on Another Zammad Server…
As usual, Google translate is your friend!
With very special thanks to Markus Neuberger,
Michel-André
Hi all,
All is working correctly with Zammad on the original NethServer but there are some problems with the email when restauring to another NethServer…
On the new server, I checked only the default user who is Nicole Braun that is created with the installation of every Zammad.
My sincere apologies for this newbee’s mistake. I am ashamed of myself
Michel-André
Hi all,
Maybe I found the problem.
Before the restoration, on the destination server, I have to rename /opt/zammad/contrib/backup/config.dist
to /opt/zammad/contrib/backup/config
I renamed the file and it seems to work…
Enough for today. Tomorrow is another day.
Michel-André
