capote
(Marko)
February 22, 2021, 11:54am
1
regarding this Rspam filter stats have reset
I tried:
redis-cli -s /var/run/redis-rspamd/rspamd --scan --pattern BAYES_* | xargs redis-cli del
But the server answers with:
Could not connect to Redis at 127.0.0.1:6379: Connection refused
What could be the cause and how to fix it?
Sincerely, Marko
Ps.:
systemctl status redis-rspamd
● redis-rspamd.service - Redis persistent key-value database Rspamd
Loaded: loaded (/usr/lib/systemd/system/redis-rspamd.service; static; vendor preset: disabled)
Active: active (running) since Mon 2021-02-22 12:30:09 CET; 15min ago
Main PID: 737 (redis-server)
CGroup: /system.slice/redis-rspamd.service
└─737 /usr/bin/redis-server 127.0.0.1:0
Feb 22 12:30:09 ns-srv01.dargels.de systemd[1]: Started Redis persistent key-value dat...d.
Hint: Some lines were ellipsized, use -l to show in full.
stephdl
(Stéphane de Labrusse)
February 22, 2021, 12:00pm
2
[root@prometheus ~]# redis-cli -s /var/run/redis-rspamd/rspamd --scan --pattern BAYES_*
BAYES_SPAM_keys
BAYES_HAM_keys
[root@prometheus ~]# systemctl status redis redis-rspamd
● redis.service - Redis persistent key-value database
Loaded: loaded (/usr/lib/systemd/system/redis.service; disabled; vendor preset: disabled)
Drop-In: /etc/systemd/system/redis.service.d
└─limit.conf
Active: inactive (dead)
Loaded: loaded (/usr/lib/systemd/system/redis-rspamd.service; enabled; vendor preset: disabled)
Active: active (running) since Tue 2021-02-16 10:57:47 CET; 6 days ago
Main PID: 817 (redis-server)
└─817 /usr/bin/redis-server 127.0.0.1:0
Feb 16 10:57:47 prometheus.de-labrusse.fr systemd[1]: Started Redis persistent key-value database Rspamd.
stephdl
February 22, 2021, 12:01pm
3
[root@prometheus ~]# ll /var/lib/redis/
total 6160
-rw-r--r-- 1 redis redis 6304186 Dec 22 2019 dump.rdb
drwxr-xr-x 2 redis redis 46 Feb 22 12:56 rspamd
[root@prometheus ~]# ll /var/lib/redis/rspamd/
total 143864
-rw-r--r-- 1 redis mail 13391108 Feb 22 12:56 dump.rdb
-rw-r--r-- 1 redis mail 133918999 Oct 25 2019 dump.rdb20191025
capote
(Marko)
February 22, 2021, 12:02pm
4
[root@ns-srv01 rspamd]# redis-cli -s /var/run/redis-rspamd/rspamd --scan --pattern BAYES_*
BAYES_SPAM_keys
BAYES_HAM_keys
capote
(Marko)
February 22, 2021, 12:06pm
6
stephdl:
it works be happy
yes, but I really want to reset my bays filter because a lot of wrong spam classifications by my user
But the reset procedure doesn’t work.
[root@ns-srv01 rspamd]# redis-cli -s /var/run/redis-rspamd/rspamd --scan --pattern BAYES_* | xargs redis-cli del
[root@ns-srv01 rspamd]# redis-cli -s /var/run/redis-rspamd/rspamd --scan --pattern RS* | xargs redis-cli del
stephdl
February 22, 2021, 12:08pm
7
read carefully what you pasted and you will see your typo…a clue look at redis
capote
(Marko)
February 22, 2021, 12:11pm
9
I like that you are trying to draw my attention to something specific. But I obviously have tomatoes on my eyes.
capote
(Marko)
February 22, 2021, 12:13pm
10
ok, not only tomatoes… I would never have had this idea
stephdl
11
it makes sense, we use a specific database path, you have to adjust it
capote
(Marko)
February 22, 2021, 12:22pm
12
Just now it works well
[root@ns-srv01 ~]# rspamc stat
Results for command: stat (0.007 seconds)
Messages scanned: 5507
Messages with action reject: 2230, 40.49%
Messages with action soft reject: 10, 0.18%
Messages with action rewrite subject: 0, 0.00%
Messages with action add header: 761, 13.81%
Messages with action greylist: 962, 17.46%
Messages with action no action: 1544, 28.03%
Messages treated as spam: 3001, 54.49%
Messages treated as ham: 2506, 45.50%
Messages learned: 252
Connections count: 0
Control connections count: 34
Pools allocated: 116
Pools freed: 81
Bytes allocated: 26.73MiB
Memory chunks allocated: 144
Shared chunks allocated: 17
Chunks freed: 0
Oversized chunks: 1
Fuzzy hashes in storage "local": 0
Fuzzy hashes in storage "rspamd.com": 1943393204
Fuzzy hashes stored: 1943393204
Statfile: BAYES_SPAM type: redis; length: 0; free blocks: 0; total blocks: 0; free: 0.00%; learned: 0; users: 0; languages: 0
Statfile: BAYES_HAM type: redis; length: 0; free blocks: 0; total blocks: 0; free: 0.00%; learned: 0; users: 0; languages: 0
Total learns: 0 <<----
after manual training:
Results for command: stat (0.003 seconds)
Messages learned: 1631
Control connections count: 2108
Pools allocated: 2196
Pools freed: 2161
Bytes allocated: 28.81MiB
Chunks freed: 0
Oversized chunks: 141
Fuzzy hashes in storage "rspamd.com": 1943430706
Fuzzy hashes stored: 1943430706
Statfile: BAYES_SPAM type: redis; length: 0; free blocks: 0; total blocks: 0; free: 0.00%; learned: 1379; users: 1; languages: 0
Total learns: 1379. <<----
stephdl
February 22, 2021, 12:31pm
13
how did you train it, would you like to add something in the wiki please ?
capote
(Marko)
February 22, 2021, 2:58pm
14
yes I can: Rspam filter stats have reset
Where is the best place for me to do this? …new article? …expand an existing one?
stephdl
February 22, 2021, 4:42pm
15
in the useful command like you found the tip to reset it, a real howto needs a place but tiny command needs a tiny place.
But you can do it like you want, do a new place and drop a link in the useful command, same for me
capote
(Marko)
February 22, 2021, 5:38pm
16
stephdl
February 22, 2021, 7:08pm
17
really good work, I added a line in the useful command
mrmarkuz
(Markus Neuberger)
February 22, 2021, 10:12pm
18
Great userguide, worked like a charm
